the video is slowing random lines. they seem to be lines from other cams.
This is messing up the mocord any ideas???
thanks
ipcs -lm && ipcs -um && ipcs -m && cat /proc/sys/kernel/shmmax
cordel wrote:So now the question, when did you put in the example shmmax and shmall from the FAQ?
Have you restarted ZM since you used the examples?
Why do I not see ZM using any shared memroy from the code I had you run, zm should have been running?
02/10/08 14:52:41.503823 zma_m4[23019].WAR-zm_monitor.cpp/874 [Approaching buffer overrun, consider slowing capture, simplifying analysis or increasing ring buffer size]
02/10/08 14:52:42.334510 zma_m4[23019].DB4-zm_monitor.cpp/865 [RI:9, WI: 0, PF = 1, RM = 9, Step = 2]
02/10/08 14:52:42.334596 zma_m4[23019].WAR-zm_monitor.cpp/874 [Approaching buffer overrun, consider slowing capture, simplifying analysis or increasing ring buffer size]
