Local PTZ with Remote camera
joedee983
Post by joedee983 »
I have successfully upgraded to 1.23.1 & Mandriva 2008, works great
I am using a mix of Remote cameras, local cameras and an IP9100 remote server.
I configure the IP9100 as a remote and it works fine. Unfortunatly the PTZ control is local ie: ttyS0
I can not figure out a way to have local control on a remote camera.
Any thoughts woulsd be appreciated.
BTW, I am a newbie with no Linux experience
Thanks,
Joe
zoneminder
Site Admin
Post by zoneminder »
This is a bit of a tricky issue. I will need to look at the source to see if you can 'hack' it to work.
Phil
joedee983
Post by joedee983 »
I found a workaround, sort of.................
When I create the remote monitor, I leave the PTZ protocol blank, it will default to PelcoD, this happens to be the protocol that I use.
The protocol box stays empty and it works.
Joe
