Image Buffer Size
chris
Image Buffer Size
Post by chris »
I try to increase the size of the Image Buffer Size (of the monitor) up to 200-300 frames but it seems to be impossible.
Have you set in your code a limitation for this parameter or it's only related with the memory size.
Thank you for your work and for your answer.
Bye
Christophe
zoneminder
Site Admin
Re: Image Buffer Size
Post by zoneminder »
Hi Christophe,
There is no limitation on the size as such. What errors or problems are you seeing? Is it not creating the shared memory (which is limited by your available RAM and some kernel configuration) or just not saving the values you give it?
Regards,
Phil,
chris
Post by chris »
The problem I see is:
If I increase the size of buffer from 300 to 400 (with w/b video camera, image size 352x288), the zmc process didn't start. I think the amount of available RAM is ok and the kernel config is standard (pre-compiled kernel debian 2.4.21-4-k6).
From zmwatch.log file:
Watchdog starting at 03/10/03 09:20:24
Watchdog pausing for 30 seconds
Can't get shared memory id:
It's not a big problem and I think it's effectively a kernel problem with shared memory, I'll try to solve it by my self if I found enough time.
Bye
Christophe
