Installed ZM on Xubuntu 7.10 following the guide in the second post of this thread and it installed fine. The guide has me install ffmpeg from the debian repository. Initially, I had the following error show up in /var/log/apache2/error.log whenever I tried to generate video:
FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2007 Fabrice Bellard, et al.
configuration: --enable-gpl --enable-pp --enable-swscaler --enable-pthreads --enable-libvorbis --enable-li$
libavutil version: 1d.49.3.0
libavcodec version: 1d.51.38.0
libavformat version: 1d.51.10.0
built on Jun 3 2007 20:59:25, gcc: 4.1.3 20070528 (prerelease) (Ubuntu 4.1.2-9ubuntu2)
Incorrect frame rate
Input #0, image2, from '%03d-capture.jpg':
Duration: 00:00:39.2, start: 0.000000, bitrate: N/A
Stream #0.0: Video: mjpeg, yuvj420p, 320x240, 2.75 fps(r)
Output #0, mpeg, to 'Event-4835-r1-s1.mpg':
Stream #0.0: Video: mpeg1video, yuv420p, 320x240, q=2-31, 200 kb/s, 5.00 fps(c)
Stream mapping:
Stream #0.0 -> #0.0
[mpeg1video @ 0xb7e3dac8]MPEG1/2 does not support 5/1 fps
Error while opening codec for output stream #0.0 - maybe incorrect parameters such as bit_rate, rate, width $
Any ideas as to why I might be getting this?
