Mocord stills list shows all frames, not just alarmed ones
jonatha
Post by jonatha »
I recently upgraded from an older version (1.21.x?) to 1.22.3.
I have a mocord camera with two zones.
With the older version, if I look at an event that has alarm frames and switch to stills, the window just shows the alarmed frames (plus a few on either side of the alarm) and each alarmed frame is outlined in red.
With the newer version, I see all the frames, and none of them is outlined in red.
Has something changed or do I have a configuration issue?
(With the newer version, the cause in the event viewer is "continuous", which seems a bit odd; I can't remember if the old version had "continuous" or "mocord". The function on the monitor is definitely set to mocord...)
P.S. The camera was originally set up as record, then later changed to mocord. I'm pretty sure zoneminder has been restarted (indeed, the machine has been rebooted) in the interim, but I will make sure I have done so when I can get admin access...)
zoneminder
Site Admin
Post by zoneminder »
I don't think a lot has changed in that area. However if you are looking at your events in list format, you will go directly to the alarmed frames if you click on the count in the alarmed frames column. If you are using the timeline view then it should be obvious which are which.
Phil
