No view on monitor when logged as a Authenticated user
Boxscratcher
Post by Boxscratcher »
While preparing the migration of my ZM Server 1.22.3 to a new HW platform running Ubuntu 7.10 LAMP Server, i faced the following problem :
- Installation process using Zoneminder over Ubuntu repositories run error free and I was able to access ZM main menu, I defined my camera & sources and tested with live Stills/streams in View mode = everything OK - i can see the sources
- Since I have different groups of users accessing the server and each of them using different view/source, I activated Authenticate user in the Systems configuration panel, defined the users, assigned them their respective sources and rights, restarted ZM as required and logged again with any of my newly created users = Not OK .... Nothing appears in my monitors/views... I also tried to switch from Still to Stream mode and from Cycle to montage without any change....Nothing displayed but a white board....
- Logged off and switched off Authenticate user logins mode, restarted ZM and I was again able to see my monitor views.....
- Tried all the possible (restart Apache, Mysql, ZM etc) and toggled Authenticate mode .... but :x no change....
Any hot tips to overcome this ....
Any support (and fortunatly solution) will be highly appreciated
JMC
rDr4g0n
Post by rDr4g0n »
just recently wrapped up a thread with the exact same problem:
http://www.zoneminder.com/forums/viewtopic.php?t=11166
________
BUY VOLCANO VAPORIZER
Boxscratcher
Dear rDr4g0n
First of all many thanks for quick reaction on that topic !
I will follow the instructions in the post and will revert with hopefully.... a success
Many thanks again.... The Linux Community is definitively the Church to be In :wink:
rDr4g0n
Post by rDr4g0n »
amen brother!
________
Extreme vaporizer
________
MICHIGAN MEDICAL MARIJUANA DISPENSARIES
Boxscratcher
Dear rDr4g0n
As promised my feedback.
Followed the instruction according your post http://www.zoneminder.com/forums/viewtopic.php?t=11166
After toggling ZM_AUTH_RELAY to "none" everything fine (toggling to "plain" did not solved the issue)
Many thanks again for your help "Padre" :lol:
rDr4g0n
Post by rDr4g0n »
Boxscratcher wrote:Dear rDr4g0n
if ya scroll down that thread some more, there is a link to an updated install package. the ubuntu repository package is a few versions older, but the newer one allows you to use authentication (which is a good thing lol).
________
EASY VAPE
________
Saturn custom sound processor
Lee Sharp
Post by Lee Sharp »
Note that after doing this you have to restart both ZM and your browser. That bit me a few times. :)
