Streaming don't work (only in live, in events it's work)
groo
Post by groo »
I have just installed ZM 1.23.1. All works fine, but if I check cambozola checkbox streaming in live doesn't work, but streaming from events works great!!!.
When I try to stream from live cambozola seems to load well, but it only shows the first image and then it freezes. But when I stream from an event all work fine, cambozola stream in a very decent frame ratio...
Any idea how to solve it?
Thanks in advance.
Groo.
zoneminder
Site Admin
Post by zoneminder »
Are you using nph-zms or ordinary zms (Options->Paths->ZM_PATH_ZMS)? Whichever one it is, try the other one and see if that makes a difference.
Phil
groo
Post by groo »
I was using nph-zms, so I changed to ordinary zms but it has no possitive effects. I have the same results. I still get cambozola running but freezes in the first frame when in live (streaming events still works fine with cambozola).
Any othe idea to try?
Thanks for your help.
Groo.
