Getting a new error now:
libphp5.so is garbled - perhaps this is not an Apache module DSO?
Here is the background of how I got to this:
OK, I found what I thought was the cause. I looked in:
/etc/apache2/mods-available
/etc/apache2/mods-enabled
and found no softlinks for php5. So I created these manually. Now I have:
lrwxrwxrwx 1 root root 27 Feb 28 11:10 php5.conf -> ../mods-available/php5.conf
lrwxrwxrwx 1 root root 27 Feb 28 13:15 php5.load -> ../mods-available/php5.load
Now when I restart apache2, I get this error (and still the download file thing):
* Forcing reload of web server
(apache2)...
apache2: Syntax error on line 116 of /etc/apache2/apache2.conf: Syntax error on line 1 of /etc/apache2/mods-enabled/php5.load: API module structure `php5_module' in file /usr/lib/apache2/modules/libphp5.so is garbled - perhaps this is not an Apache module DSO?
I researched google and found nothing to actually solve the problem (except to reinstall or recompile - which I refuse to do for since this was working previously). Here is what some of the troubleshooting revealed:
/var/lib/php5# ldd /usr/lib/apache2/modules/libphp5.so
linux-gate.so.1 => (0xffffe000)
libcrypt.so.1 => /lib/libcrypt.so.1 (0xb7ad1000)
libssl.so.0.9.8 => /usr/lib/libssl.so.0.9.8 (0xb7a91000)
libdb-4.3.so => /usr/lib/libdb-4.3.so (0xb79b4000)
libgdbm.so.3 => /usr/lib/libgdbm.so.3 (0xb79ae000)
libbz2.so.1.0 => /lib/libbz2.so.1.0 (0xb799d000)
libz.so.1 => /usr/lib/libz.so.1 (0xb7989000)
libpcre.so.3 => /usr/lib/libpcre.so.3 (0xb7969000)
libresolv.so.2 => /lib/libresolv.so.2 (0xb7956000)
libm.so.6 => /lib/libm.so.6 (0xb792e000)
libdl.so.2 => /lib/libdl.so.2 (0xb792a000)
libnsl.so.1 => /lib/libnsl.so.1 (0xb7913000)
libgssapi_krb5.so.2 => /usr/lib/libgssapi_krb5.so.2 (0xb78f7000)
libkrb5.so.3 => /usr/lib/libkrb5.so.3 (0xb787e000)
libk5crypto.so.3 => /usr/lib/libk5crypto.so.3 (0xb785b000)
libcom_err.so.2 => /lib/libcom_err.so.2 (0xb7857000)
libxml2.so.2 => /usr/lib/libxml2.so.2 (0xb7748000)
libc.so.6 => /lib/libc.so.6 (0xb7605000)
libcrypto.so.0.9.8 => /usr/lib/libcrypto.so.0.9.8 (0xb74b9000)
/lib/ld-linux.so.2 (0x80000000)
libkrb5support.so.0 => /usr/lib/libkrb5support.so.0 (0xb74b4000)
/usr/sbin# ./apache2 -V
Server version: Apache/2.2.3
Server built: Apr 27 2007 13:08:02
Server's Module Magic Number: 20051115:3
Server loaded: APR 1.2.7, APR-Util 1.2.7
Compiled using: APR 1.2.7, APR-Util 1.2.7
Architecture: 32-bit
Server MPM: Prefork
threaded: no
forked: yes (variable process count)
Server compiled with....
-D APACHE_MPM_DIR="server/mpm/prefork"
-D APR_HAS_SENDFILE
-D APR_HAS_MMAP
-D APR_HAVE_IPV6 (IPv4-mapped addresses enabled)
-D APR_USE_SYSVSEM_SERIALIZE
-D APR_USE_PTHREAD_SERIALIZE
-D SINGLE_LISTEN_UNSERIALIZED_ACCEPT
-D APR_HAS_OTHER_CHILD
-D AP_HAVE_RELIABLE_PIPED_LOGS
-D DYNAMIC_MODULE_LIMIT=128
-D HTTPD_ROOT=""
-D SUEXEC_BIN="/usr/lib/apache2/suexec"
-D DEFAULT_PIDLOG="/var/run/apache2.pid"
-D DEFAULT_SCOREBOARD="logs/apache_runtime_status"
-D DEFAULT_LOCKFILE="/var/run/apache2/accept.lock"
-D DEFAULT_ERRORLOG="logs/error_log"
-D AP_TYPES_CONFIG_FILE="/etc/apache2/mime.types"
-D SERVER_CONFIG_FILE="/etc/apache2/apache2.conf"
/usr/sbin# uname -a
Linux camserver 2.6.15-26-386 #1 PREEMPT Thu Aug 3 02:52:00 UTC 2006 i686 GNU/Linux
/etc/apache2/mods-available# cat php5.conf
<IfModule mod_php5.c>
AddType application/x-httpd-php .php .phtml .php3
AddType application/x-httpd-php-source .phps
</IfModule>
/etc/apache2/mods-available# cat php5.load
LoadModule php5_module /usr/lib/apache2/modules/libphp5.so
/etc/apache2/mods-enabled# ls -la
total 8
drwxr-xr-x 2 root root 4096 Feb 28 13:15 .
drwxr-xr-x 7 root root 4096 Feb 28 11:21 ..
lrwxrwxrwx 1 root root 38 May 23 2007 alias.load -> /etc/apache2/mods-available/alias.load
lrwxrwxrwx 1 root root 33 May 23 2007 auth_basic.load -> ../mods-available/auth_basic.load
lrwxrwxrwx 1 root root 33 May 23 2007 authn_file.load -> ../mods-available/authn_file.load
lrwxrwxrwx 1 root root 36 May 23 2007 authz_default.load -> ../mods-available/authz_default.load
lrwxrwxrwx 1 root root 38 May 23 2007 authz_groupfile.load -> ../mods-available/authz_groupfile.load
lrwxrwxrwx 1 root root 33 May 23 2007 authz_host.load -> ../mods-available/authz_host.load
lrwxrwxrwx 1 root root 33 May 23 2007 authz_user.load -> ../mods-available/authz_user.load
lrwxrwxrwx 1 root root 32 May 23 2007 autoindex.load -> ../mods-available/autoindex.load
lrwxrwxrwx 1 root root 36 Mar 24 2007 cgi.load -> /etc/apache2/mods-available/cgi.load
lrwxrwxrwx 1 root root 26 May 23 2007 dir.conf -> ../mods-available/dir.conf
lrwxrwxrwx 1 root root 26 May 23 2007 dir.load -> ../mods-available/dir.load
lrwxrwxrwx 1 root root 26 May 23 2007 env.load -> ../mods-available/env.load
lrwxrwxrwx 1 root root 35 May 24 2007 jk.conf -> /etc/apache2/mods-available/jk.conf
lrwxrwxrwx 1 root root 35 May 24 2007 jk.load -> /etc/apache2/mods-available/jk.load
lrwxrwxrwx 1 root root 27 May 23 2007 mime.load -> ../mods-available/mime.load
lrwxrwxrwx 1 root root 34 May 23 2007 negotiation.load -> ../mods-available/negotiation.load
lrwxrwxrwx 1 root root 31 May 23 2007 setenvif.load -> ../mods-available/setenvif.load
lrwxrwxrwx 1 root root 29 May 23 2007 status.load -> ../mods-available/status.load
lrwxrwxrwx 1 root root 40 Mar 24 2007 userdir.conf -> /etc/apache2/mods-available/userdir.conf
lrwxrwxrwx 1 root root 40 Mar 24 2007 userdir.load -> /etc/apache2/mods-available/userdir.load
/usr/sbin# ldd apache2
libm.so.6 => /lib/libm.so.6 (0xb7f7e000)
libpcre.so.3 => /usr/lib/libpcre.so.3 (0xb7f5e000)
libaprutil-1.so.0 => /usr/lib/libaprutil-1.so.0 (0xb7f43000)
libldap_r.so.2 => /usr/lib/libldap_r.so.2 (0xb7f0e000)
liblber.so.2 => /usr/lib/liblber.so.2 (0xb7f02000)
libdb-4.4.so => /usr/lib/libdb-4.4.so (0xb7e07000)
libpq.so.5 => /usr/lib/libpq.so.5 (0xb7deb000)
libsqlite3.so.0 => /usr/lib/libsqlite3.so.0 (0xb7d8c000)
libexpat.so.1 => /usr/lib/libexpat.so.1 (0xb7d6b000)
libapr-1.so.0 => /usr/lib/libapr-1.so.0 (0xb7d48000)
libuuid.so.1 => /lib/libuuid.so.1 (0xb7d45000)
librt.so.1 => /lib/librt.so.1 (0xb7d3c000)
libcrypt.so.1 => /lib/libcrypt.so.1 (0xb7d0e000)
libpthread.so.0 => /lib/libpthread.so.0 (0xb7cf7000)
libdl.so.2 => /lib/libdl.so.2 (0xb7cf2000)
libc.so.6 => /lib/libc.so.6 (0xb7baf000)
/lib/ld-linux.so.2 (0xb7faf000)
libresolv.so.2 => /lib/libresolv.so.2 (0xb7b9c000)
libsasl2.so.2 => /usr/lib/libsasl2.so.2 (0xb7b86000)
libgnutls.so.13 => /usr/lib/libgnutls.so.13 (0xb7b19000)
libssl.so.0.9.8 => /usr/lib/libssl.so.0.9.8 (0xb7ad8000)
libcrypto.so.0.9.8 => /usr/lib/libcrypto.so.0.9.8 (0xb798c000)
libkrb5.so.3 => /usr/lib/libkrb5.so.3 (0xb7913000)
libcom_err.so.2 => /lib/libcom_err.so.2 (0xb7910000)
libtasn1.so.3 => /usr/lib/libtasn1.so.3 (0xb7900000)
libgpg-error.so.0 => /usr/lib/libgpg-error.so.0 (0xb78fb000)
libnsl.so.1 => /lib/libnsl.so.1 (0xb78e4000)
libz.so.1 => /usr/lib/libz.so.1 (0xb78d0000)
libgcrypt.so.11 => /usr/lib/libgcrypt.so.11 (0xb7884000)
libk5crypto.so.3 => /usr/lib/libk5crypto.so.3 (0xb7861000)
libkrb5support.so.0 => /usr/lib/libkrb5support.so.0 (0xb785b000)
