ubuntu 7.10 setup help needed
Hi I am very new to linux and have a ubuntu 7.10 desktop setup running for my ftp files. I have been tryng to setup ZM for the last 3 days but can not seem to get it to show any video or still images in a webpage.
As ubuntu 7.10 comes with ZM as part of the distro I was wondering if anyone has a very easy to follow guide on what is needed to do after installing it. I am getting a little confused with the other guides on the forum as they don't seem to be inline with what is needed for a ubuntu 7.10 install.
I am sure it must be very easy once the correct procedure is followed, so any help would be very welcome.
thank you
Studiodaz.
thank you
Studiodaz.
I will have a look again to see if I can find the 7.10 install guides, thanks.
The problem I was having is it will not show any image in the webpage monitor box that opens up. My cam works with xawtv but I can not do a zmu -d <device_path> -q -v' Is it correct to input zmu -d device_0 -q -v' ?
thanks again
Studiodaz
thanks again
Studiodaz
ive successfully set up zm on ubuntu using the zm package available in the ubuntu repository (getting those should be pretty easy) and a few steps that are outlined in the documentation. here is the link to what you probably need http://www.zoneminder.com/wiki/index.ph ... rom_a_.deb
and this is the imporatant info from that link:
________
IOLITE REVIEW
________
MERCEDES-BENZ OM352 ENGINE SPECIFICATIONS
the other issue you should be aware of is that the version in the ubuntu repository does not work correctly with login authentication enabled. you can dl an updated version in order to fix taht as mentioned here http://www.zoneminder.com/forums/viewtopic.php?t=11166Link Apache
Restart Apache
sudo apache2ctl restart
suid zmfix
Run zmfix
zmfix -a
Fix export problem
kernel.shmall = 134217728
kernel.shmmax = 134217728
if these steps dont work, then youll need to post some log info so we can see whats going on with your isntall.PeterHoward wrote: You can pull the 1.22.3-10 from ftp://ftp.northern-ridge.com.au/zoneminder and then a dpkg -i of it should upgrade nicely.
________
IOLITE REVIEW
________
Oops!!!
AAAAAGGGGGHHHHHH!!!!!!!coke wrote:Anyone else notice a large vacancy on Peter's site as far for ZoneMinder packages?
I got too keen about cleaning out in preparation for 1.23. And then forgot that I had. Use the mirror at ftp://twisted.bluecherry.net/zoneminder until I restore thing tonight (my time).
Re: Oops!!!
Actually, it's even more embarrasing than that. They are there, I just moved them and forgotPeterHoward wrote:AAAAAGGGGGHHHHHH!!!!!!!coke wrote:Anyone else notice a large vacancy on Peter's site as far for ZoneMinder packages?
ftp://ftp.northern-ridge.com.au/zoneminder/1.22.3/
- Location: The land downunder.. where women glow and men chunder, can you hear? can you hear the thunder?
I tried this again...
(xubuntu 7.10 with zoneminder1.22-10)
and it seems to have returned to the land of the living for the moment.sudo ln -s /etc/zm/apache.conf /etc/apache2/conf.d/zoneminder.conf
Restart Apache
suid zmfix
Run zmfix
zmfix -a
Fix export problem
when you update, i think the file permissions go back to the default settings. when you redid the above commands, you set the permissions again so that ZM could work.
________
Buy Herbalaire
________
Hero honda achiever specifications
________
Buy Herbalaire
________
