bttv_norm=3 -> PAL-NC
linuxfd
Post by linuxfd »
Hi all,
If you use Source tab and select Device Format you have the option to set as 0=PAL 1=NTSC and I think 3 = Auto, I need to set my 2nd card Pico2000 to PAL-NC.
Tried to pass this parameter in modules.conf with
option bttv card=7 bttv_norm=3 # PAL-NC
Has anyone got a Pico2000 working in colour, it works in windows but I am sure its set to PAL-NC
Looked at the videodev.h to see if it was possible to see codes for other norm settings, but lost on that one.
Have tried numbers 0,1,3
regards
fred
victor_diago
Post by victor_diago »
just ONE input of pico2000 works in gray.
to fix this, use card=45 and then use the inputs as channel 0 1 2 and 4, DONT use 3 because 3 is gray.
regards.
victor diago
fernando
Post by fernando »
pal-nc? where are you linuxfd?
you have a pal-nc camera?
Fernando
aot2002
Post by aot2002 »
yes i got the pico to work off ebay with 8 color cameras
actually it works good 5 frames per second with 2 cameras per card
jay
linuxfd
pico2000 card working
Post by linuxfd »
Hi All,
first thanks for you help.
here is my conf file for Mandrake 10
modules.conf
probeall usb-interface usb-ohci
above snd-trident snd-pcm-oss
#ptions i2c-algo-bit bit_test=1
# card 45 = pico 2000 tuner = 0
options bttv card=1,45 tuner=0,0 gbuffers=4
options i2c-algo-bit bit_test=1
#options bttv card=7 bttv_norm=3 radio=0
alias eth0 8139too
modprobe.conf
alias eth0 8139too
install snd-trident /sbin/modprobe --first-time --ignore-install snd-trident && { /sbin/modprobe snd-pcm-oss; /bin/true; }
install usb-interface /sbin/modprobe usb-ohci; /bin/true
remove snd-trident { /sbin/modprobe -r snd-pcm-oss; } ; /sbin/modprobe -r --first-time --ignore-remove snd-trident
And the card works with my microPCTV
why did I ask about pal-nc well with the windoze software it works in that mode!!!
But when I set it up with Zoneminder I used 0=PAL maybe I got mis understood on that one.
my next one has anyone got a package list conf file to install Debian, and source.list conf file
regards
fred
PS could you please post your example conf files for the pico2000
linuxfd
Post by linuxfd »
Hi All,
modules.conf
alias eth0 8139too
modprobe.conf
alias eth0 8139too
regards
fred
