i have camera plustek
i tried with the fillowing code to view in internet explorer
<object id="Player" height="480" width="640" border="1"
classid="CLSID:745395C8-D0E1-4227-8586-624CA9A10A8D">
<param name="AutoStart" value="1">
<param name="UIMode" value="none">
<param name="MediaType" value="jpeg">
<param name="NetworkTimeout" value="5000">
<param name="MediaUsername" value="admin">
<param name="MediaPassword" value="password">
<param name="MediaURL" value="http://192.168.1.24:8084/cgi/mjpg/video.cgi">
</object>
can we add this camera in zoneminder
i tried with 320*240 and also 640*480 but i cannot see any image or video
i configured like
root:password@192.168.1.24
port :8084
path /cgi/mjpg/video.cgi
by the above code in ie i can see the video
any help will be appreciated
thanks in adv
byee....
help need for plustek
by the above adress and path
i get acess refused
http://192.168.1.24:8084/cgi-bin/Stream ... ookie00000
i get streaming video by this adress
if configure this with zoneminder
i cannot get nothing
0 fps and blank
any idea
i get acess refused
0 fps and blank
any idea
by the above code
http://admin:password@192.168.1.24:8084 ... /video.cgi
i get video in ie as well as in mozilla
but i cannot access in zm
my conf
port 8084
/cgi/mjpg/video.cgi
320*240
i have configured on axis and plustek
axis works and plustek do nothing
in the console window it is in orange
any help please
a
my conf
port 8084
/cgi/mjpg/video.cgi
320*240
any help please
a
did you manage to aquire the stream? otherwise someone suggested
"at least you can pull jpeg snapshots off of the camera
http://82.233.39.160:90/snapshot.jpg"
is this possible with zoneminder right now?
that way cams could be watched over from windows pcs and data stored on linux using zoneminder
- knight-of-ni
After buying an IP1000 from Newegg last November, I finally got around to trying this camera out.
I tried the various remote host path's suggested in this thread, and the following thread...
http://www.zoneminder.com/forums/viewto ... ht=plustek
All in all, I was unable to get this camera to output a usable image without using IE or the junk Windows software the camera came with... not even "/snapshot.jpg" worked for me.
Anyway, just thought I would second the motion that one should avoid using this camera.
