Random broken images
LucaTNT
Post by LucaTNT »
Hi, thank you for the great software!
I've used ZM on OpenSUSE 2 years ago, but not very much.
Now I use Kubuntu 7.10 and ZM 1.22.3 with a simple Logitech Quickcam (the same I used with OpenSUSE).
The webcam is set as monitor, and sometimes it shows a broken image:
instead of the correct one.
I noticed that in the syslog there was this error:
[12169.377707] quickcam: frame lost
repeated over and over.
I think this is due to a too high framerate, but I set it 1 FPS.
What can I do?
robi
Post by robi »
is your load ok? As USB cams use CPU a lot, outside ZM.
v1.25.0 + Ubuntu Linux 12.04 Server
LucaTNT
Post by LucaTNT »
Yes, it was.
I'm not at home now, but I'm sure that load was between 0.50 and 0.70, so I think it was ok
coke
Broken images
Post by coke »
Ubuntu 7.10, ZoneMinder 1.23.2 (though I experienced the same with 1.22.3-10), Firefox 2.0.0.12
When I view a monitor, or montage, often the images don't show up the first time when browsing on the actual server with firefox. A reload often but doesn't always fix the problem. Running the same version of firefox on my nearby windows box doesn't experience this problem. Konqueror doesn't seem to have this problem on the server.
Any thoughts? I could switch to konqueror on the server, so it's not a huge deal, but it's weird.
On a side note, my 5 640x480 cameras in montage view show up cropped in Firefox (either platform). In konqueror, there are scroll bars attached to each image. In Firefox, there are not, though the arrow keys will move a clicked image. Just checked IE6 on a windows box, no scroll bars, arrow keys don't help. (Not that I have any intention of using IE)
robi
Re: Broken images
Post by robi »
coke wrote:Ubuntu 7.10, ZoneMinder 1.23.2 (though I experienced the same with 1.22.3-10), Firefox 2.0.0.12
Type about:config in Firefox's address bar.
Alter the following parameters to 100:
network.http.max-connections
network.http.max-connections-per-server
network.http.max-persistent-connections-per-proxy
network.http.max-persistent-connections-per-server
Restart Firefox. 8)
