zm and perl 5.10
arekm
zm and perl 5.10
Post by arekm »
Looks like some things do not work well with perl 5.10 :-(
[root@cctv ~]# zmupdate.pl -v 1.23.1
Bareword found in conditional at /usr/bin/zmupdate.pl line 152.
Bareword "ZM_DYN_DB_VERSION" not allowed while "strict subs" in use at /usr/bin/zmupdate.pl line 354.
BEGIN not safe after errors--compilation aborted at /usr/bin/zmupdate.pl line 536.
[root@cctv ~]# perl --version
This is perl, v5.10.0 built for i686-pld-linux-thread-multi
Even more:
Bareword "ZM_CHECK_FOR_UPDATES" not allowed while "strict subs" in use at /usr/bin/zmupdate.pl line 117.
Bareword "ZM_DYN_CURR_VERSION" not allowed while "strict subs" in use at /usr/bin/zmupdate.pl line 121.
Bareword "ZM_DYN_LAST_VERSION" not allowed while "strict subs" in use at /usr/bin/zmupdate.pl line 122.
Bareword "ZM_DYN_LAST_CHECK" not allowed while "strict subs" in use at /usr/bin/zmupdate.pl line 123.
Bareword "ZM_EMAIL_TEXT" not allowed while "strict subs" in use at /usr/bin/zmupdate.pl line 617.
Bareword "ZM_MESSAGE_TEXT" not allowed while "strict subs" in use at /usr/bin/zmupdate.pl line 627.
Execution of /usr/bin/zmupdate.pl aborted due to compilation errors.
or
Bareword "ZM_SHM_KEY" not allowed while "strict subs" in use at /usr/share/perl5/vendor_perl/ZoneMinder/SharedMem.pm line 225.
Compilation failed in require at /usr/share/perl5/vendor_perl/ZoneMinder.pm line 37.
BEGIN failed--compilation aborted at /usr/share/perl5/vendor_perl/ZoneMinder.pm line 37.
Compilation failed in require at /usr/bin/zmpkg.pl line 45.
BEGIN failed--compilation aborted at /usr/bin/zmpkg.pl line 45.
or
Bareword "ZM_MAX_RESTART_DELAY" not allowed while "strict subs" in use at /usr/bin/zmdc.pl line 577.
Bareword "ZM_MAX_RESTART_DELAY" not allowed while "strict subs" in use at /usr/bin/zmdc.pl line 579.
schweini
Post by schweini »
try editing /usr/bin/zmupdate.pl , and eithe comment out (or delete) the line 'use strict;', or add a 'no strict 'subs';' after that line.
arekm
Post by arekm »
I did workaround these problems (by dropping strict usage).
I'm actually indicating problems with current stable perl with a hope that developers will fix these in future version.
Thanks!
zoneminder
Site Admin
Post by zoneminder »
I can't say I have heard of perl 5.10, unless that is the version number of perl 6? If so there are lots of major changes which I will have to address once it gets out in the wild. What is your distro and version?
Phil
arekm
Post by arekm »
http://dev.perl.org/perl5/news/2007/perl-5.10.0.html
It's new stable in 5.x series. No big changes but some small changes require updating own apps.
Distro: PLD-Linux.org, Th (development)
zoneminder
Site Admin
Interesting, thanks for that. I will take a look and try and find a VM that I can play with it in.
Phil
cordel
Post by cordel »
I can create one in xen if you don't mind working on a remote machine and feel ambisous about it, affaid I have no IP cams though, I would have to setup a confige for you to pull images from local traffic cams er something :roll:
Just let me know, would take about 20 min to set up. It is what I spent all the money on this server for anyway.
