Internet Explorer, Cambozola, and iPhone
semenzat
Post by semenzat »
I use four systems, Ubuntu GNU/Linux, Mac OS, Windows, and iPhone. When I noticed that Internet Explorer didn't support streaming, I installed cambozola and it worked right away. But, now the iPhone stopped working. It shows a blank white space instead of the stills. If I turn off cambozola, the iPhone shows the stills again.
I suspect that the server thinks the iPhone supports whatever cambozola is doing, but the iPhone doesn't really support that. So it may be a bug. I don't see, unfortunately, an obvious workaround, but maybe someone does?
Thanks!
Luigi
mycal
Post by mycal »
Well the iPhone does support multi-part jpg, but just not the
version that comes out of zoneminder. I haven't had a chance
to figure out why because it works on my MJPG stream camera
and my own generated MJPG, but there is something about
the way zoneminder does it, that fails to allow it to work.
cambozola doesn't run on the iphone as there is no java support.
-M
