Configure error
mikesjays
Configure error
Post by mikesjays »
When I try to configure 1.23.2 I get this error and I'm not sure what it is looking for.
"configure: error: zm requires PHP::Serialization"
This is on a fedora 8 box.
Here the configure options I'm using
./configure --with-webdir=/var/www/html/zm --with-cgidir=/var/wwwcgi-bin ZM_DB_HOST=loclhost ZM_DB_NAME=video ZM_DB_USER=video ZM_DB_PASS=MyPAssWordHere ZM_SSL_LIB=openssl CFLAGS="-g -O3 -march=pentium4" CXXFLAGS="-g -O3 -march=pentium4"
cordel
Post by cordel »
You need to install the Perl php serialization module from most likely the Fedora extras repo.
Otherwise you will have to use CPAN.
zoneminder
Site Admin
Post by zoneminder »
It is possible that that module is not available via yum in which case you will have to do it manually. Just type
perl -MCPAN -eshell
If it is your first time it will ask if you want to configure it. Say 'y' if you want to answer a bunch of questions or 'n' (easier) to just accepts defaults. Then type
install PHP::Serialization
and then when it has finished
quit
to exit.
Phil
mikesjays
Post by mikesjays »
Hey thanks, I tried to install the RPM and it did not work. When I type the first line I get the complaint
"perl -MCPAN -eshell
Can't locate CPAN.pm in @INC (@INC contains: /usr/lib/perl5/site_perl/5.8.8/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.7/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.6/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.5/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.8 /usr/lib/perl5/site_perl/5.8.7 /usr/lib/perl5/site_perl/5.8.6 /usr/lib/perl5/site_perl/5.8.5 /usr/lib/perl5/site_perl /usr/lib/perl5/vendor_perl/5.8.8/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.7/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.6/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.5/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.8 /usr/lib/perl5/vendor_perl/5.8.7 /usr/lib/perl5/vendor_perl/5.8.6 /usr/lib/perl5/vendor_perl/5.8.5 /usr/lib/perl5/vendor_perl /usr/lib/perl5/5.8.8/i386-linux-thread-multi /usr/lib/perl5/5.8.8 .).
BEGIN failed--compilation aborted."
Any idea what I'm missing in perl?
zoneminder wrote:It is possible that that module is not available via yum in which case you will have to do it manually. Just type
perl -MCPAN -eshell
quit
to exit.
mikesjays
Post by mikesjays »
Ok I got it. I have to install CPAN
