Mpeg4
mpeg4 or any other conditional refresh system has serious implications. I for one prefer jpeg, yes it needs more space but the image quality is better and hard disks aint exactly dear. Mpeg would be of no use for me personally except for live monitoring, everything else should be jpeg IMHO
James Wilson
i'm thinking to bandwidth and to disk space.jameswilson wrote:mpeg4 or any other conditional refresh system has serious implications. I for one prefer jpeg, yes it needs more space but the image quality is better and hard disks aint exactly dear. Mpeg would be of no use for me personally except for live monitoring, everything else should be jpeg IMHO
also some cheaper IP cameras have builtin for mjpeg and mpeg4
but mjpeg is implemented without any standard
(such trendnet IP301), so i'm hoping that mpeg4 is implemented
in some better way
It will result in a poorer picture. There is no way to get the quality still frames from a mpeg stream. This, for me, is the primary selling point of zoneminder. We store high quality pictures, not low quality streams. I vote not to support hardware that will result in a degradation of zoneminder quality.
Agree with you all, but the market of MPEG4-only IP cameras is growing very quickly. If ZM doesn't catch up to support these, the other teeny-weeny Winblows similar applications will gain space again.
Currently a MPEG4-only IP camera costs about three time less than a JPEG, or MJPEG capable camera. At least this is the situation in Europe.
v1.25.0 + Ubuntu Linux 12.04 Server
And the quality of the resulting still will be about 5 times less. Sometimes, you do get what you pay for.robi wrote:Currently a MPEG4-only IP camera costs about three time less than a JPEG, or MJPEG capable camera. At least this is the situation in Europe.
In case of ZM currently cannot capture from MPEG, there would be some chance eg. using VLC (http://www.videolan.org) to capture from MPEG then stream it as JPEG so that ZM can handle it
As above MPEG is not an ideal format for storage and has many issues.
MPEG is ideal for streaming, but jpeg for storage.
Maybe jpeg 2000 would be a better direction but that has its own implications
James Wilson
Actually mpeg is a great method of storage. It is smaller, the container provides for audio tracks, and is great for streaming... SO long as you don't mind losing allot of video detail.
mpeg capture is in the works, Phil has been working on it for the last couple years I think and will probably cause the next epoch in the version number.
Whether or not the storage will change from jpeg, I have no idea as jpeg is preferred by most to retain the detail, but it is also possible to create an mpeg container that holds mjpeg streams, no loss of detail and you can add audio tracks although not any better for streaming, it might not be much different than we are doing now. Although doing this would take allot more work so I don't see the containers going from jpeg snapshots to anything else very soon.
As for when, soon as Phil has a working alpha model, I'm sure he will put it out so we can work out the kinks and get it to beta, and stable but there is not even a rough idea when that will be, it could be a year or two. All depends on how much time he has to volunteer to working on it and how stubborn making it work reliably is.
lolActually mpeg is a great method of storage. It is smaller, the container provides for audio tracks, and is great for streaming... SO long as you don't mind losing allot of video detail.
James Wilson
