saa7134 >8 channels
saa7134 >8 channels
Hello
I want to use 4 china boards with saa7x chipsets, so i have 16 channels.
everything ok, i tested this boards with ZM and it worked, but the problem appears when i need to use options, becouse when i try :
[root@atlantis usr]# modprobe saa7134 card=33,33,33,33,33,33,33,33,33,33,33,33,33,33,33,33
FATAL: Error inserting saa7134 (/lib/modules/2.6.24.3-12.fc8/kernel/drivers/media/video/saa7134/saa7134.ko): Invalid argument
dmesg:
card: can only take 8 arguments
saa7134: `33' invalid for parameter `card'
first 8 channels work, but the rest ... the same story:
saa7134[4]: subsystem: 1131:0000, board: UNKNOWN/GENERIC [card=0,autodetected]
any ideeas ?
dmesg:
any ideeas ?
Re: saa7134 >8 channels
I'd say that it's a limit of either the driver and/or the chip.liviud wrote: FATAL: Error inserting saa7134 (/lib/modules/2.6.24.3-12.fc8/kernel/drivers/media/video/saa7134/saa7134.ko): Invalid argument
dmesg:
any ideeas ?
problem solved
For saa7134 chipset this problem can be solved in few steps
1. download kernel sources
2. edit drivers/media/video/saa7134/saa7134.h , search for
#define SAA7134_MAXBOARDS 8
#define SAA7134_INPUT_MAX 8
and change values in what you need
3. compile
4. reboot and play
i hoppe this will help
3. compile
4. reboot and play
Re: problem solved
Thanks, that a helpful post mate. I have the same problem with 2 cards (8 ch and 4 ch) and now solvedliviud wrote:For saa7134 chipset this problem can be solved in few steps
3. compile
4. reboot and play
this is my lspci:
00:00.0 Host bridge: Intel Corporation 82865G/PE/P DRAM Controller/Host-Hub Interface (rev 02)
00:01.0 PCI bridge: Intel Corporation 82865G/PE/P PCI to AGP Controller (rev 02)
00:1d.0 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #3 (rev 02)
00:1d.3 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #4 (rev 02)
00:1d.7 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB2 EHCI Controller (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev c2)
00:1f.0 ISA bridge: Intel Corporation 82801EB/ER (ICH5/ICH5R) LPC Interface Bridge (rev 02)
00:1f.1 IDE interface: Intel Corporation 82801EB/ER (ICH5/ICH5R) IDE Controller (rev 02)
00:1f.3 SMBus: Intel Corporation 82801EB/ER (ICH5/ICH5R) SMBus Controller (rev 02)
00:1f.5 Multimedia audio controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) AC'97 Audio Controller (rev 02)
01:00.0 VGA compatible controller: nVidia Corporation NV18 [GeForce4 MX 4000] (rev c1)
02:01.0 PCI bridge: Hint Corp HiNT HB4 PCI-PCI Bridge (PCI6150) (rev 04)
02:02.0 PCI bridge: Hint Corp HB6 Universal PCI-PCI bridge (non-transparent mode) (rev 11)
02:05.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
03:08.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
03:09.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
03:0a.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
03:0b.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
03:0c.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
03:0d.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
03:0e.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
03:0f.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
04:0c.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
04:0d.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
04:0e.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
04:0f.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
It runs well anyway, but I'm quite unsatisfied with full 8 monitor in montage so I grouped into 2 groups, each 4 monitor ..
It runs Zoneminder-1.23.2 on Slackware-12, just run as server, no monitor, keyboard, mouse. Only run services required by zm and me I need ssh
cam settings:
func = modect
size = 320x240, RGB24
buffer = default
MaxFPS = AlarmMaxFPS = 12
Browser Firefox 2.0.0.4 w/ config:
network.http.pipelining = true
network.http.proxy.pipelining = true
network.http.pipelining.maxrequest = 32
network.http.max-connections-* = 32
network.http.max-persistent-connections-* = 32
cpu load
idle = 0.51
peak = 1.96
this post http://www.zoneminder.com/forums/viewtopic.php?t=6419 seems work for me
cam settings:
func = modect
buffer = default
cpu load
idle = 0.51
peak = 1.96
Re: problem solved
I'm having the same iusse making work two 8 chip saa7134 cards at the same time on ubuntu server..liviud wrote:For saa7134 chipset this problem can be solved in few steps
3. compile
4. reboot and play
Have anyone got a patch to solve that?
