Export Failed
- Victor1974
Please type;
ffmpeg -version
- Victor1974
ffmpeg -version
FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2007 Fabrice Bellard, et al.
configuration: --enable-gpl --enable-pp --enable-swscaler --enable-pthreads --enable-libvorbis --enable-libtheora --enable-libogg --enable-libgsm --enable-dc1394 --disable-debug --enable-shared --prefix=/usr
libavutil version: 1d.49.3.0
libavcodec version: 1d.51.38.0
libavformat version: 1d.51.10.0
built on Jun 3 2007 20:59:25, gcc: 4.1.3 20070528 (prerelease) (Ubuntu 4.1.2-9ubuntu2)
ffmpeg SVN-rUNKNOWN
libavutil 3212032
libavcodec 3352064
libavformat 3344896
- Victor1974
I am assuming that you are using my debian/ubuntu package. -10 is built without ffmpeg support. There had been enough problems with it that I decided it was more honest to have it removed rather than in and not working properly. So, unfortunately, it working from the command line is irrelevant to it working from inside zoneminderVictor1974 wrote:That version of ffmpeg to install for zoneminder 1.22.3-10?
Que version de ffmpeg deberia instalar para zoneminder 1.22.3-10?
General question - is ffmpeg required for export?
Further, in looking at a different thread in 1.22.3 I have confirmed that export does work (at least for me) on 1.23.2-1
PJH
PS
1.23.2-1 does have ffmpeg support thanks to help from Alexander Kushnirenko.
PJH
PJH
- Victor1974
update to Feisty and work without problem
Actualice a Feisty y trabajo sin problema
my new question is:
my pc two hhd wanted that in the second disc which this empty recorded all the events, that I must modify aside from ZM_DIR_EVENTS, ZM_DIR_IMAGES, ZM_DIR_SOUNDS?
thanks for help me.
Mi nueva pregunta es:
mi equipo tiene dos hhd quisiera que en el segundo disco que esta vacio se grabaran todos los eventos, que debo modificar aparte de ZM_DIR_EVENTS, ZM_DIR_IMAGES, ZM_DIR_SOUNDS?
Gracias por la ayuda.
my new question is:
thanks for help me.
