Hi Forum,
I have:
Slackware 9.1, ZM 1.19.2 running on a 1.1gig Athlon with 256 meg RAM and a Grantec Xgrand 4 port capture card with 2 black and white and 2 color vista cameras.
This is the output of zmu -d 0 -q -v
Video Capabilities
Name: BT878(Grand X-Guard / Trust
Type: 233
Can capture
Overlay onto frame buffer
Can clip
Uses the frame buffer memory
Scalable
Video Channels: 16
Audio Channels: 0
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 640
Height: 480
Picture Atributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32512
Contrast: 27648
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 1 Attributes
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 2 Attributes
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 3 Attributes
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 4 Attributes
Channel: 4
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 5 Attributes
Channel: 5
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 6 Attributes
Channel: 6
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 7 Attributes
Channel: 7
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 8 Attributes
Channel: 8
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 9 Attributes
Channel: 9
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 10 Attributes
Channel: 10
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 11 Attributes
Channel: 11
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 12 Attributes
Channel: 12
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 13 Attributes
Channel: 13
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 14 Attributes
Channel: 14
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 15 Attributes
Channel: 15
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
I am currently running one camera at 640x480 but the quality is aewful, especially when there is motion. See http://www.ginnungagap.net/zmexample20040624.jpg for a screenshot
How can I improve it so that I can see faces and number plates?
I think that is all the info i have for now, if anything else is needed apologies for missing it out!
Thanks in advance
Pete
Image Quality Problems
- lazyleopard
