after several days of normal registering of events I got names for all events as "new event" instead of "event %" and duration and so on marked as 0 length.
When I click to see the even I get a messege to check my web logs for a specifical number of an error - another for every event.
I looked up in apache log and what i see is "table .zm/Frames is marked as crashed and should be repaired"
what can/should I do about it and waht is it?
SQL error? plz help
I am betting you had an unplanned reboot. This often results in a broken events table.
http://www.zoneminder.com/wiki/index.ph ... atabase.3F
still after auto repair all tables in MySQL
when trying to see the new event:
An error has occurred and this operation cannot continue.
For full details check your web logs for the code 'CE654E'
in zmaoudith log
04/18/08 12:57:56.245527 zmaudit[3286].FAT [Can't execute: Table './zm/Frames' is marked as crashed and should be repaired]
can any one plz tell me where I should read the relevant error messages at all? as I cant even find that error code in my logs
in zmaoudith log
thx for your help guys,
I could manage it using phpmyadmin
but still I know what I did wrong now: I hadnt stopped mysql before trying to correct the tables. You dont have to stop it using myphpadmin though.
one more question then
as this error appears again and again have you an idea what can I add to cron to check the tables every day?
thx in advance
thx in advance
