PTZ cabling
josepy
PTZ cabling
Post by josepy »
Just set up a PTZ camera and now I'm looking for cabling. I'd like to find a "single" cable that combines the video coax (BNC), power, and 2 wires for RS-485 controls. In all the searching I've done I'm not really finding what I want. Mostly what I've found is the coax & power combination.
Can anyone recommend a reliable company that makes such a cable at a reasonable price?
Joe
cordel
Post by cordel »
Depending on the length, it may be cheaper to get a converter that passes power and ptz control signals through the coax, otherwise it's not standard and requires a special order to aquire it and is very expencive usualy three times more or worse.
It's usualy cheaper to get the Siamese Cable and the seperate for your rs485.
Video translators are not really cheap either but sure simplify the job if you can justify them.
http://www.supercircuits.com/index.asp? ... rodID=4495
zoneminder
Site Admin
Post by zoneminder »
You can also use CAT5, feeding the video via baluns through one pair and then using a pair each (or more) for power and PTZ. I really only use CAT5 nowadays.
Phil
josepy
Post by josepy »
Thanks Phil
After a lot of hunting I found a cable that I think fits my needs.
http://esentia.com/Products/203
Cheers
Joe
darkpaw
pins
Post by darkpaw »
How many pins/wires does that cable have?
curtishall
Re: PTZ cabling
Post by curtishall »
You might look at http://store.bluecherry.net/product_p/v ... _ppins.htm
josepy wrote:Just set up a PTZ camera and now I'm looking for cabling. I'd like to find a "single" cable that combines the video coax (BNC), power, and 2 wires for RS-485 controls. In all the searching I've done I'm not really finding what I want. Mostly what I've found is the coax & power combination.
Joe
Curtis Hall
Bluecherry
www.bluecherrydvr.com
josepy
Post by josepy »
darkpaw,
I haven't actually received it yet, and I didn't actually inquire, but I'm counting on 2 for power, 2 for control and coax (BNC). if you blow the image up a bit thats what it looks like to me ;)
Thanks curtishall
Joe
josepy
Post by josepy »
Hold the presses .... wrong cable. The picture they have is not the cable they sent :(
Major hassel, my apologizes if I've lead anyone else astray!
Joe
curtishall
josepy wrote:Hold the presses .... wrong cable. The picture they have is not the cable they sent :(
Joe
Are you talking about this product: http://esentia.com/Products/203 or this product: http://store.bluecherry.net/product_p/v ... _ppins.htm
If it's the Bluecherry product make sure you send a picture of what you received to support@bluecherry.net so we can create a RMA. We do not want you receiving the wrong parts.
Curtis Hall
Bluecherry
