Dear all,
I just bought a new IP cam and I'm trying to use it with ZoneMinder.
It is Micronet SP5511W (http://www.micronet.info/model_detail.a ... cification)
I know, that it streams MJPEG at the following URL:
http://xx.xx.xx.xx/cgi/mjpg/mjpeg.cgi
But first, I have to enter login & password (HTTP authentification).
I tried to configure it the following way in ZoneMinder:
1) Source Type: Remote
2) Remote Host: admin:admin@xx.xx.xx.xx
3) Remote Port: 80
4) Remote Path: /cgi/mjpg/mjpeg.cgi
Does anyone know, what should I try to do?
MJPEG stream from Camera Micronet SP5511W
Re: MJPEG stream from Camera Micronet SP5511W
And I forgot to mention that it does not work - I can see only black picture in ZoneMinder.
Regards,
Onidlo
Regards,
Onidlo
Just to let you know,
I found out that this webcam does not send valid HTTP headers and valid JPEG.
I had to make some changes in zm_remote_camera.cpp to get it working.
The webcam uses Java applet to play the video. When I looked at the source code of this applet (by using Cavaj Java decompiler), I did not find nothing special - but it was written in a way, that allowed it to skip the first invalid sequence of 28 bytes of JPEG (I think it wasn't programmers aim).cordel wrote:Thats a shame![]()
Do they market their own software?
As we found out, the webcam uses same software as described here:
http://www.zoneminder.com/forums/viewtopic.php?t=11574
Hello guys and sorry for reviving this old post.
Your forum has been of great help to me so far.
I was given 8 Micronet SP5520 (same as SP5510 with WiFi), to build a small surveilance system, and obviously my choice of software, was ZM.
Unfortunately I'm stuck with the same problem. I've been searching around for a solution, with no luck
It's been a couple of years since this post started. Hasn't anybody find a workaround yet, or some trick for these cameras to properly work with ZM?
Any advices for a newbie pls?
Re:
You may also use online Java decompiler. It is more recent than Cavaj and does not require installation.onidlo wrote: ↑Sun May 11, 2008 9:34 amThe webcam uses Java applet to play the video. When I looked at the source code of this applet (by using Cavaj Java decompiler), I did not find nothing special - but it was written in a way, that allowed it to skip the first invalid sequence of 28 bytes of JPEG (I think it wasn't programmers aim).cordel wrote:Thats a shame![]()
