Home Security System
ric3125
Post by ric3125 »
Does anyone know of a open source Home Security System. Thanks
coke
Post by coke »
I read about one somewhere, it was called Zone something. Zoneminder, perhaps. :)
darkpaw
ZM
Post by darkpaw »
I was wondering who would be the first to say it. :)
ric3125
Post by ric3125 »
NO more like a Brinks system. Keypad, alarm, monitoring service. stuff like that.
cordel
Post by cordel »
I figured that was what you were implying, Unfortunately no, and ZoneMinder certainly can't take the place of those very easily, at least not without supplementing it with PIRs and door switches and more coding to help prevent false positives.
ric3125
Post by ric3125 »
I dont want zoneminder to do this. I was looking for info on a open source Home Security System software. If there was any out there.
JohnnyLaww
Post by JohnnyLaww »
If you want a standalone intrusion detection system, you're gonna need some hardware.. Grab a kit from HERE or from
http://www.youralarmstore.com/. Then you can do all the opensource installing you want. With the DSC Power 832 systems, you can either program it via the keypad (which is a PITA) or get a serial cable from one of the above links and d/l the programming software from DSC. It may even come with the kits these days. I have installed these systems, and they are very nice and easy.
ric3125
Post by ric3125 »
Ok Thanks Johnny.
mike.neugent
Post by mike.neugent »
I also found a linux based system http://dvr.neugent.net
Lee Sharp
Post by Lee Sharp »
mike.neugent wrote:I also found a linux based system http://dvr.neugent.net
I was looking all over your site, and never found a software download. You wouldn't be hiding it in violation of the GPL would you?
cordel
Post by cordel »
That would be a shameless plug.... :evil:
