I think I discovered that the SNC cameras are supported under 1.22.3.
I'll check that today and post the patches if not...
Maybe even get the camera control script finished? Sorry - been working a lot lately and no free time to hack...
Sony SNC-M3W support ready for testing.
So, I've posted the newest patch files for the SNC-M3W and SNC-M1W here as a gzipped tar file containing two patches [tested/working] and the latest [buggy] control script.
I'll start a new thread that explains patching and recompiling, and then update the Wiki page with the same info.
Basically:
Open a shell.
Go to the ZM sources wherever you originally unpacked them.
Go into the src directory:
shell> cd src
Extract the files:
shell> tar zvxf /path/to/your/downloaded/zm_snc_v2_patches.tgz
Backup the original files you are about to patch:
shell> cp zm_remote_camera.cpp zm_remote_camera.cpp.original
shell> cp zm_remote_camera.h zm_remote_camera.h.original
Patch your sources:
shell> patch < zm_remote_camera-1.22.3-SNCM.cpp.patch
shell> patch < zm_remote_camera-1.22.3-SNCM.h.patch
Copy the zmcontrol-SNC-M3W.pl to /usr/local/bin:
shell> cp zmcontrol-SNC-M3W.pl /usr/local/bin
Go back up to the ZM root directory and recompile and install:
shell> cd ..
shell> make && make install
Go setup the camera control script...more on that in the new post...check the Wiki as well...and let me know if it works!
Basically:
Open a shell.
shell> cd src
Extract the files:
Patch your sources:
shell> cd ..
Sony M1 Patch link down.
Can anyone post the latest Sony SNC-M1 patch? I have a dozen of these cameras and would like to get them working with ZM.
Thanks,
Matt
Thanks,
Matt
