I have problems with geting my system to work running from liveCD. It works under XP and Pico2000. A stand alone system.
It is a P4 with too 4 chanel PCI PAL camera card, and 4 cameras connected to one card. (The other card has no cameras at the moment.)
Onboard grafikcard SIS650.
ZM dont display any cameras.
Using xawtv results in a window showing a picture that looks like a CRT-monitor running on the wrong refrechment freq. It is only the signal from one camera that is beeing pickt up.
dmesg:
bttv: Bt8xx card found (0)
bttv0: i2c: checking for MSP 34 xx @ 0x80 .. not found
I sopose this means that something is not working.
Please, before telling me that I supplied to litle information:
1. How do I (mount?) acess my floppy drive (or USB).
2. How do I pipeline the shell output to a text file on a floppy (or USB).
3. Is there an copy/paste capable editor on the liveCD (In case of running on a computer connected to internet).
Cameras dont work under linux (XP ok)
Re: Cameras dont work under linux (XP ok)
http://www.tuxfiles.org/linuxhelp/mounting.htmlberik wrote:1. How do I (mount?) acess my floppy drive (or USB).
http://dsl.org/cookbook/cookbook_toc.html#TOC56berik wrote:2. How do I pipeline the shell output to a text file on a floppy (or USB).
more specifically:
http://dsl.org/cookbook/cookbook_5.html#SEC56
There is vim if your running headless or gvim I think in the desktop menu.berik wrote:3. Is there an copy/paste capable editor on the liveCD (In case of running on a computer connected to internet).
otherwise you can use putty on winblows to ssh into the box running live CD.
Also the dmesg is only a small piece, run "dmesg |grep bttv" with out the quotes of coarse.
Now I have managed to get the dmsesg:
xawtv -hwscan only returns an empty file.
But on screen it looks something like this:
Well, to me this is swahili soo I hope some one can give me a pice of advice.
P.S.
Any solution why some shell comands returns an empty file?
Mounting via konqueror does not work, but doing it the hard way does.
And then the floppy showes up in konqueror.
Linux video capture interface: v1.00
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
PCI: Found IRQ 10 for device 0000:00:09.0
PCI: Sharing IRQ 10 with 0000:00:09.1
PCI: Sharing IRQ 10 with 0000:00:10.0
bttv0: Bt878 (rev 17) at 0000:00:09.0, irq: 10, latency: 32, mmio: 0xdfdff000
bttv0: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv0: gpio: en=00000000, out=00000000 in=00f36fff [init]
tveeprom 0-0050: Huh, no eeprom present (err=-121)?
bttv0: using tuner=-1
bttv0: i2c: checking for MSP34xx @ 0x80... not found
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv: Bt8xx card found (1).
PCI: Found IRQ 9 for device 0000:00:0b.0
PCI: Sharing IRQ 9 with 0000:00:0b.1
bttv1: Bt878 (rev 17) at 0000:00:0b.0, irq: 9, latency: 32, mmio: 0xdfdfd000
bttv1: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv1: gpio: en=00000000, out=00000000 in=00f36fff [init]
tveeprom 1-0050: Huh, no eeprom present (err=-121)?
bttv1: using tuner=-1
bttv1: i2c: checking for MSP34xx @ 0x80... not found
bttv1: i2c: checking for TDA9875 @ 0xb0... not found
bttv1: i2c: checking for TDA7432 @ 0x8a... not found
bttv1: i2c: checking for TDA9887 @ 0x86... not found
bttv1: registered device video1
bttv1: registered device vbi1
bt878: AUDIO driver version 0.0.0 loaded
bt878: Bt878 AUDIO function found (0).
PCI: Found IRQ 10 for device 0000:00:09.1
PCI: Sharing IRQ 10 with 0000:00:09.0
bt878_probe: card id=[0x0],[ <NULL> ] has DVB functions.
bt878(0): Bt878 (rev 17) at 00:09.1, irq: 10, latency: 32, memory: 0xdfdfe000
bt878: Bt878 AUDIO function found (1).
PCI: Found IRQ 9 for device 0000:00:0b.1
PCI: Sharing IRQ 9 with 0000:00:0b.0
bt878(1): Bt878 (rev 17) at 00:0b.1, irq: 9, latency: 32, memory: 0xdfdfc000
Linux agpgart interface v0.101 (c) Dave Jones
agpgart: Detected SiS 650 chipset
agpgart: AGP aperture is 128M @ 0xe0000000
bootsplash 3.1.6-2004/03/31: looking for picture...<6> silentjpeg size 13182 bytes,<6>...found (800x600, 9805 bytes, v3).
port 60-60 [-xvport60]
type: Xvideo, video overlay
port 61-61
same
Port 62-62
type: Xvideo, image scaler
name: sis 300/315/330 series Video Overlay
/dev/video0:OK [-device /dev/video0]
type:v4l2
name: BT878 video (*** UNKNOWN/GENER
flags: overlay capture tuner
P.S.
I have done some more checking.
There are video, video0 and video1 in /dev . There are not different chanels.
If i´m not misstaking, i need to sett this card manually to 77, but I dont find how to do this exactly.
It would be a great help to get the exact comands with parameters and in the correct order.
There is alot of talking about modprobe, rmmod and insmod in older post, but it doesent help me since I'm complite beginner in administrating a Linux system.
P.S.
I have tried rmmod bt878 , whitch is denied.
And I tried rmmod bttv, whitch is denied because of bt878.
Soo I'm stuck.
P.S.
Soo I'm stuck.
