Hello all,
I got a Trendnet TV-IP422W, which is their new PT model with LEDs and WIreless, in yesterday, and have spent the day playing with it. Unfortunately, I haven't been able to get it working with ZM yet.
I decompiled the Java applet that it uses, and it points to /cgi/mjpg/mjpeg.cgi I tried plugging that into ZM, but no luck. I ran a wget, and was able to run the resulting file in VLC. However, VLC popped up plenty of errors, suggesting the there is the same non-standard jpeg problem as exists in the IP110 and some other cameras.
Incidentally, I got the same Content-Type: multipart/mixed; boundary=--myboundary when I ran wget, as referenced in http://www.zoneminder.com/forums/viewtopic.php?t=11574
On the bright side, it looks like the PT controls should be easy to implement, as they are just calls to variations of http://x.x.x.x/admin/ptctl.cgi?move=$ARG.
Is there any way to write a camera "driver" so that these 28 bytes can be taken into account for this camera only?
Trendnet TV-IP422W
have you tried to play with ffmpeg at all? I've played around with the TV-IP400 quite a bit (wrote the PTZ driver) and was able to grab its stream using ffmpeg.
It may be possible to pass the stream through ffmpeg and have it clean it up a bit.
I'd be interested in working on streaming/ptz support for this camera, except I don't own one yet
I'm also wondering if the patch mentioned here might work:
http://www.zoneminder.com/forums/viewto ... t=trendnet
The Airllink101 SkyIPCam 747W is based on the same hardware and firmware (only difference is the Airlink camera lacks a USB port and lacks MPEG4 streaming).
Someone has contributed a lot of useful information on getting Airlink camera to work with zoneminder here:
http://www.zoneminder.com/forums/viewtopic.php?t=12238
and a PTZ module for zoneminder here:
http://www.zoneminder.com/forums/viewtopic.php?t=12271
Give the contributions in those threads a try, there is a good chance they will working on your Trendnet camera.
I feel I'm so close to getting my TrendNet TV-IP410 PTZ controls working, but I keep running into the same error. Can anyone help with just this error:
No matter what control protocol I use, even if I modify it myself, and no matter what control address, I get the same errors everytime.
There's obviously just a broken link somewhere in here, but I'm not quite savvy enough to realize it.
SFPeter to the rescue??
04/22/09 20:49:55.273644 zmcontrol[21044].ERR [Error check failed: '500 No Host option provided']
Did you provide the IP for the host in the control section? If it's using http try user:password@aaa.bbb.ccc.ddd
for the host in the control tab.
Yes, I have tired both conical name and ip address, with user account info in it. Neither works.cordel wrote:Did you provide the IP for the host in the control section? If it's using http try user:password@aaa.bbb.ccc.ddd
