delete event erases db but doesn't erase filesystem
pluttero
Post by pluttero »
hi,
the problem is in the subject: if I delete an event, the corresponding jpeg files are untouched. The user running the db has full rights over the events dir and there are not corresponding errors inside logs...
thanks,
Paolo
jameswilson
Post by jameswilson »
if you disable fast delete then as soon as you delete then the delete will start
James Wilson
kevin_robson
Post by kevin_robson »
Or restart zm after deletion
pluttero
Post by pluttero »
ops I didn't see that option: thank you guys :)
Paolo
