Corrupt JPEG data
sgocken
Corrupt JPEG data
Post by sgocken »
My second problem. (Created 2 threads)
Based on what I have read The Corrupt JPEG lines mean that it can't stream the images fast enough.
But, this seems strange to me. I have tried this on 2 different Axis 2100s.
Both show this error. The first was also being accessed by different server software, so I had figured the error was caused by that.
But the Axis 2100 that the logs are refering to is only be accessed by ZoneMinder on a 100Mbit switched connection.
'zmc -m 2' started at 04/07/12 15:15:25
'zmc -m 2' starting at 04/07/12 15:15:25, pid = 4149
Corrupt JPEG data: premature end of data segment
Invalid JPEG file structure: two SOI markers
'zmc -m 2' crashed at 04/07/12 15:15:25, exit status 1
Use of uninitialized value in hash element at /usr/local/bin/zmdc.pl line 332, <CLIENT> line 1.
zoneminder
Site Admin
Post by zoneminder »
There have been a number of issues with this kind of thing on Axis cameras. I've done a patch which hopefully addresses it and which will be in the next release. Unfortunately as I don't get the problem I can't tell if it fixes it but if you want I can mail it to you to try out. Assuming you have the same problem of course.
It's nothing to do with network speed or resources, and more to do with rather inconsistent stream structure. Are you using the mpjpeg stream from the camera or just the jpeg one? I have a 210 and don't see any problems.
Phil,
sgocken
Post by sgocken »
I am just using the jpeg stream. I would be happy to try the patch. I have both Axis 2100s and Axis 205s to test with. Just e-mail it to me. Thanks
zoneminder
Site Admin
I would suggest using the mpjpeg stream first as it's much more efficient and also faster!
If you don't get anywhere with that then I'll mail you the patch. I'm trying to get a release out shortly anyway.
The paths I'm using on my cameras for mpjpeg streams are as follows, though I think it depends on your firmware to some degree.
205: /mjpg/video/mjpg
210: /axis-cgi/mjpg/video.cgi?resolution=320x240
Phil
sgocken
Post by sgocken »
Well changing to the mpeg stream seems to have stopped the jpeg errors.
The capture daemon is using alot more CPU using the mpeg stream.
Well I am going to add a bunch more cameras to this system and see how it works.
zoneminder
Site Admin
It is using more CPU because you are probably getting 25fps or more rather than about 4-5 before. I usually find it worthwhile setting the 'max client FPS' in the Axis admin pages to about 10fps otherwise you can get overwhelmed.
Phil,
sgocken
Post by sgocken »
I turned the frame rate down, but I am now getting about 2 minutes of lag time on the live view.
zoneminder
Site Admin
Did you turn it down in the Axis admin pages rather than the ZM monitor config? If you do the latter for network cameras it will just end up with all the images in a huge long queue.
Phil,
sgocken
Post by sgocken »
Well I made the change in ZM. I can't find a place to change the frame rate in the Axis 2100.
sgocken
Post by sgocken »
Well can you send me the patch to:
sgocken at icsincorporated dot com
I would like to see how it works with the jpg stream. The mpeg stream is using way too much CPU.
I am going to have about 36 cameras running on this server.
And 640 x 480 is a requirement.
