Can't get shared memory id '7a6d0001 error in SUSE 11.0
I installed 1.23 using Yast in SuSe 11.0.
Install went fine. I can access web page ,
I can configure monitor. I have issue when I start to watch monitor. Web page froze up and ZMC and ZM service get frozen as well. I can not sopt Zm service.
This is what I have in ZMwatch
07/05/08 18:34:14.776357 zmwatch[3474].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
07/05/08 18:34:14.777040 zmwatch[3474].INF [Restarting capture daemon for New, shared memory not valid]
Debug log
07/05/08 09:48:00.837519 zms[3801].WAR-zm_monitor.cpp/327 [Shared memory not initialised by capture daemon, some query functions may not be available or produce invalid results]
Messages log
Jul 5 18:34:14 server1 zmwatch[3474]: ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
Jul 5 18:34:14 server1 zmwatch[3474]: INF [Restarting capture daemon for New, shared memory not valid]
Jul 5 18:34:15 server1 zmdc[3433]: INF ['zmc -d /dev/video' stopping at 08/07/05 18:34:15]
When i run
cat /proc/sys/kernel/shmall
I am getting
134217728
cat /proc/sys/kernel/shmmax
I am getting
134217728
I did search all forums and try increasing or decreasing memory setings with no success.
I am running 2 Ghz Pentium with 2 GB of ram and ATI TV wonder card. Eveything worked fine in SUSE 10.2 and with 1.22 version.
I am dying for somebody to help me with this.
Debug log
Messages log
When i run
I am getting
134217728
I am getting
134217728
Same problem on suse 11 and fedora 9
I believe its a kernel bug. Just waiting for the later kernels.
http://www.zoneminder.com/forums/viewtopic.php?t=11545
As far as I know v4l support was broken in the early versions of 2.6.25 but got fixed later. Sadly the kernel version of opensuse is a bit too old so that the bug still exist. As a solution you can try to update the kernel or wait till this is fixed.
Keep in mind that firefox 3 has also an issue with zoneminder http://www.zoneminder.com/forums/viewtopic.php?t=11775
hope this help
hope this help
1.23.3 & OpenSuse 11.0
Kevin:
Did you have to downgrade to FireFox 2 from 3?
Thanks,
ck
Thanks,
ck
