Time Calculations and Such
WarpKat
Post by WarpKat »
The way ZM 1.23.3 calculates time for events is a bit odd.
Instead of taking events within the same hour, it takes events from the hour prior, in addition to the current hour, and it appears it's getting this info from somewhere but I can't fathom where to look first for it.
Anyone else having this issue or know how to fix it?
jameswilson
Post by jameswilson »
id say your clock is wrong then
James Wilson
WarpKat
Post by WarpKat »
Yanno - I didn't grasp the concept.
Past hour is a point in time, so clicking at the events for the past hour for a given point in time will give you from that point in time going backwards one hour.
My bad. I thought if you clicked within a specific hour, it only gave you events for that hour of the clock.
