Hi.
I have a problem with the purge filter. I configured it to purge all events when disk percent is greater that 50%.
The problem is that the filter start to delete events but it delete more events than necessary.
i.e. I configured the filter for when the disk is to 50% start delete events limit to 1 event, when the disk is 50% the filter start to delete events and it finally deleting events when the disk is to 42%.
Is it normally?
Thanks.
¿Problem with purge filter?
Depends on how you have ZM_OPT_FAST_DELETE, ZM_FILTER_EXECUTE_INTERVAL, ZM_AUDIT_CHECK_INTERVAL, and ZM_RUN_AUDIT configured
If you use fast delete, then you're depending on zmaudit to clean the hard drive. If the filter runs every 120 seconds and zmaudit runs every 600, that means that zmfilter will have run 5 times with the drive at or over the drive percentage you specified meaning that 5 events will be marked for deletion before the deletion actually occurs.
If you uncheck ZM_OPT_FAST_DELETE then the event(s) as you specified to be selected will be removed each time the filter runs until it is under the percentage you have put for the filter.
So depending on your settings, yes this might be expected.
Thanks.
I have ZM_OPT_FAT_DELETE disable and ZM_RUN_AUDIT enable.
Any suggestion for that problem?
if you are limiting the filter to 1 event every run then i cant see why its deleting more, are you sure you have this limit set?
Also try disabling fast delete this will make the purge flter do the deleting, its possible that purge is getting way ahead of zmaudit.
James Wilson
This doesn't solve your purge-when-full filter issue, but 8gb? You can find an external esata, firewire, usb 2 drive, etc. A quick glance at newegg.com shows an external 500 gig for $108, and a tererabyte for $179.99 (after $30 rebate).
Even at low frame rates, low resolution, you're not going to get a lot out of 8 gigs.
raul_denia wrote:Hi.
My disk is 8gb, its a virtual machine run over VMWARE.
One event takes a 3MB of space.
Any suggestion?
