Better motion detection?
michl080
Post by michl080 »
sry i dont understand how to apply a patch
patch -p1 < zoneminder-1.23.3-motion-6.patch
try
patch -p1 <zoneminder-1.23.3-motion-6.patch
note there is no space behind the "<".
and don't apply the patch in the src directory, run in in the parent directory.
Michael
sledgehammer
Post by sledgehammer »
It seems to me that a lot of this work has already been done in the 'Motion' program. Its got a smart-mask feature to filter out moving branches etc, its got an auto noise filter which, err, filters out noise and then there is the despeckle feature that removes general uninteresting gunk (couldn't think of a better word for it)
In my system I found setting Zoneminder up for motion detection was very difficult so chose to use 'Motion' instead which was successful. However I preferred the Zoneminder web interface over the various efforts that support 'Motion'.
I was in the end able to marry and run 'Motion' and Zoneminder together with 'Motion' telling Zoneminder when actual motion had been detected and 'undetected' (using zmtrigger.pl) . Both programs were capturing from a bttv card at the same time which, I believe, is a feature of V4L. It is also possible to run 'Motion' at a lower capture frame rate and resolution to that of Zoneminder.
There are issues however:
1) sometimes a 'motion ceased' message goes missing and Zoneminder carries on recording for hours. This usually happens when there is a sudden system full load. A nightly backup in my case.
2) I can only get as far as Linux kernel 2.6.20 after that motion and Zoneminder don't want to play any more. May be due to issues with V4l2 and the compatibility layer to V4L
My system is basic but I am running four b/w cameras at 384x288 at 8fps and get very good motion detection and have been for months. Over the last few days the sun and wind has caused a number of false triggers so I have been tweaking the despeckle feature on 'Motion' which has helped a lot. If the weather is as predicted for tomorrow I will be able to confirm if I have improved things.
So has anybody else done something similar to this? preferred 'Motion's' motion detection to Zoneminders?
And finally is it worth looking at the detection routines in 'Motion' ripping them out and putting them in to Zoneminder?
jameswilson
Post by jameswilson »
I agree that while the zm motion detection is amazing i have struggled to understand it lol
I doubt phil would look at motion code and vice versa, but maybe if we understood the features your on about we could impliment them
James Wilson
SyRenity
Post by SyRenity »
Hi.
This is interesting - in fact I suggested about a year ago of looking at motion as the motion detection replacement.
Perhaps motion could be put to a separate module, and enabled by users?
overly
Post by overly »
Could you post a URL for Motion so I could take a look at it?
I've googled and found several motion detection software examples, but not the one you're referring to.
Thanks!
Bluecherry PV-149 4-port capture card
Topica TP-936WIR-30C camera
Cheap Harbor Freight camera
HP Athlon 64 X2 w/ 2GB
Slackware 13 - 2.6.29.6-smp kernel
SyRenity
Post by SyRenity »
mike548141
Is this integrated now
Post by mike548141 »
Has this new motion detection code been integrated into the main code base now?
Thanks,
MC
enzo86
Re: Is this integrated now
Post by enzo86 »
mike548141 wrote:Hi,
Thanks,
MC
BUMP, has any of this code been included in the latest release?
BlueH2O
Post by BlueH2O »
I think this would probably help me alot. Has there been any progress?
cookacounty
Re: Better motion detection?
Post by cookacounty »
+1 for using "Motion" integrated into ZM.
Motion pretty much works out of the box for my cams. After hours of messing with the ZM motion detection my findings was all but useless for anything but the simplest of cases. Very little documentation on what the blobs and filters do.
I thought I read somewhere that ZM didn't want to use motion because of the ffmpeg licensing.
I think that Motion does NOT require ffmpeg libraries, it just supports using them.
Overall I love ZM, it just needs better motion detection!
