Is there any reason to use 64 over 32bit right now? I looked through the forums and it seemed split, or maybe leaning a bit towards 32bit making more sense. If i were to install on a 64bit CentOS installation, would i run up against any issues? Sorry if this looks like a repeat, but i never saw a definitive answer anywhere.
Cullen
64bit gains
Personally unless its a huge server with lots of ram i cant see the benefit of 64 bit yet.
But thats just me
But thats just me
James Wilson
64 bit
For ZoneMinder type applications:
A 64-bit processor will improve both the encoding and decoding of video. Better still, when you view a video file on a 64-bit desktop, you'll see a noticeable difference in speed, resulting in more frames per second and a more film-like playback.
Then there are those who want to go Virtual big time.
Give it 12 to 18 Months and you will wonder why you asked.
I dumped my 64-bit OS recently in favour of an easy life. I got most of the apps I wanted working fine, but it was often a struggle. Having said that, I think there are far fewer problems with 64-bit now than there were a couple of years ago. But at the moment it's still a finely balanced decision. For those who really need 64-bit crunch-power it''s probably worth the pain. For those, like me, who don't need that power, I think 32-bit is still the way to go.
As you say, though, give it a year or 18 months and things will be much improved.
This brings up another question - what is a big enough server? Right now I'm using a dual xeon 3.06, with 4GB of ram and a 5TB array. I installed the 32bit version, just because it looked like it was going to be a pain and i didn't want to deal with it. There will be about 6-8 cameras to start, but we will definitely be adding more as time goes on. I was hoping to get a dual dual-core or quad cpu machine, but this is what we had lying around. Will it be enough to last a while or should i start shopping around now? Should i have used x64?
i think it will be fine mate, sounds like a beast
James Wilson
I have been running opensuse 10.2 64bit version for over a year now on my ZM installation. Recently i also installed a mailsystem on the same machine. Including Squirrel webmail, amavis virusscan and spamassassin spamfilter. I also installed webmin. I can honestly say that I didn't think a second about the fact my suse system was 64 bit when I installed the above.
At work I have been running 64 bit versions of opensuse for 3+ years now on our companys webserver, and suse for almost 2 years on a second server that hosts the web of several of our customers. This one even runs php 4 and php 5 simultanously (two apache installations runing side by side).
And even a third server with suse 64 bit with VMWare on top of that has been running for about a year now. On this one we have at least 8 virtual machines (win xp and win 2003 servers) running at any time.
Not a single glitch on any of the above servers... ever.
I can not se any reasons for not using a 64 bit version of suse/opensuse. How the situation is for other distributions I don't know.
