Zoneminder hangs - no responce from the browser
tanner
Post by tanner »
This not necessarily a zoneminder problem but when I am viewing events the event will stop and the browser window will have the message about transfering data from etc. Most of the time it will start again after a wait of up to a couple of minutes. Occasionally (like now) it will not recover and I cannot look at other events or even logout. If I try to logout the box appears but does not get populated. I restarted ZM, mysql and apache (after running mysqlcheck) and the system was all right for a 10 minutes but stopped again.
Before I thought it may have been my wireless connection and router but that has not caused any problems with any Internet connection today. I have checked system, zm, mysql and apache logs and cannot see anything wrong. The pc is not busy with 87% idle on the CPU. The versions I run are below. Anybody got any idea where the problem may lie.
Zoneminder 1.23.3
mysql 5
apache 2.2.8
Firefox 3.0.1
kernel 2.6.20-gentoo-r8
kevin_robson
Post by kevin_robson »
Firefox 3.0.1
http://www.zoneminder.com/forums/viewtopic.php?t=11775
Its not compatible. There's a few threads. Try using seamonkey just for ZM.
Lee Sharp
Post by Lee Sharp »
FF3 does not close mjpeg streams, so it can fill your system. (each end) Reboot the browser to clear one end. Run 'sudo apache2ctl restart' to clear the other. I am just about to put 'sudo apache2ctl restart' in chron over this crap. I can't believe they released it like that, and STILL haven't patched it.
lookie
Post by lookie »
Thanks for this post and followups. Thought I was loosing my mind. Swore it was network, mysql or something else. I thought I would give "Flock" browser a try but deleted all my events. I dont' have time at the moment to generate sufficient events to evaluate Flock's performance.
Seem the Firefox people were more interested in generating a download "record" and less interested in quality.
tanner
Post by tanner »
thanks for the replies. I don't seem too be getting email alerts. Never mind.
Ok I will try another browser. May go back to opera. Has anyone tried it?
kevin_robson
seamonkey works, but it is a bit rubbish
lookie
Post by lookie »
the flock browser works fine
