Archive Events to MPEG Video
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
narmar
Post by narmar »
helo
i would like to archive events older than 1 day as mpeg. i was looking on forum, and found some hints, but i think i would be nice if such a filter was default in zm like purgewhenfull. after a day i'm quit sure that nothing happend but would like to keep everything for few days. jpg's take a lot of space. that is why i think autoarchiving oldest event as mpeg (for ex. once a day) would be very nice.
cheers
jameswilson
Post by jameswilson »
if you do this you will loose access to the footage from the web i/f as sson as you remve the jpgs.
I dont think it should be a default as too many would use it without understanding it, and then be confused when all the events went.
I also think mpeg is a poor starage system for security as the interesting detail pixelates, but thats a whol other subject.
Hard disks are cheap these days so i see less and less need for mpeg based compression on std cams.
James Wilson
narmar
Post by narmar »
i know, but if names of files would be like "monitor-date.mpg" it would be enaught.
yes, but for me it wpuld be better to keep few days in very good quality jpg's and as much as i can in mpeg's
not always you need very good quallity, sometimes you only need to know what peoples do.
cheers
