dvr controls
dvr controls
Hi all,
I have installed zoneminder 1.23.3 on Ubuntu 8.04 64 bit AMD , and all works OK . But the dvr controls don't work. I can see them, but they don't respond.
I installed mootools in my zm directory , I saved it as mootools.js. When I open a monitor in my firefox error console I can see "Ajax is not defined" in mootools.ext.js (line 50) as a first error, the other errors are related to it
can you help me to solve the problem ?
Thanks !
Thanks !
Still hoping for a very quick reply on this. It seems that no matter if we use mootools or cambozola neither will allow us to control the video playback mechanisms. This is a rather critical issue for me at the moment and I can confirm that the same errors are showing for me.
I wonder if we're using too new of a mootools package and if so, can someone refer us to the proper version that will work and will no throw the error at line 50 in mootools.ext.js (which I assume is not finding the proper 'Ajax' variable definition from mootools.js?
I'm also seeing a similar error in index.php at line 94 with the 'Ajax' var. Also a few undefined vars in index.php around line 282 ('streamCmdReq.request( streamCmdParms+"&command=1" );').
Actually, whenever I run any command on the Feed view I receive errors from within index.php. Such as trying to stop the feed: streamCmdReq.request( streamCmdParms+"&command=3" );
and then of course it gives me the Undefined value error.
Please do advise ASAP.
Possible solution?
I am seeing this same problem on Ubuntu 8.04 amd64 with ZM 1.23.3. The problem appears to be caused by mootools-1.2. mootools1.11 had an Ajax class. This is not present in 1.2 (although I think most of its functions have been moved into the Request class). I briefly looked at changing the PHP code for ZM to work with the new version of mootools, but for now it would be faster to get mootools-1.11. I don't have a copy so if someone else does can they post a link?
Thanks,
the_crowbar
Thanks,
the_crowbar
I've hosted this file for about a month, it took me a long time to track it down originally.
http://www.doubleburgerbar.com/mootools/
take mootools.js file
Also included on my live CD.
http://www.doubleburgerbar.com/watchdog/
http://doubleburgerbar.com/watchdog/watchdog-v2.iso is the latest Debian based iso,
Looks like the url is no longer valid, does anyone still have this available?hushpuppy wrote:I've hosted this file for about a month, it took me a long time to track it down originally.
watchdog is, htp://www.doubleburgerbar.com/watchdog/
I've not touched watchdog for almost a year, but have decided to upgrade it to 1.24, will update on the relevant forum when completed.
In the meantime, if you want a beta version, just contact me, or reply back here.
