Controlling Vivotek PZ6112 with ZM
Hello, I've trying to control my Vivotek PZ6112 with zoneminder.
That camera uses the same controls as the one in this post:
http://www.zoneminder.com/forums/viewto ... ht=vivotek
I have NOT been able to get a shred of success.
I've followed the guide in the post, and nothing.
Then I noticed it was for a really old version of ZM and tried to adjust accordingly, changed paths and stuff.
Still no success.
I believe it's not even using the script, as I am getting this error en error.log:
"Can't connect: No such file or directory at /usr/share/perl5/ZoneMinder/Debug.pm line 349
ZoneMinder::Debug::Fatal('Can\'t con4r55nect: No such file or directory') called at /usr/bin/zmcontrol.pl line 153"
I also read in the post that zoneminder said this script would be added to the next version (said so in 09 Jul 2003). So I'm wondering if maybe I just can't find it....
Can someone shed any light on this matter? I really, really need to get this working....
Still no success.
Your are correct, that script is for a older version of ZM. Unfortunately none of us have this cam to redo the control script and test against so it's not included in the main trunk as we have nothing to test against as things change. Since 1.23.x all control scripts have been converted to perl modules so it would need to be completely redone and we have no way to make sure it works.
I've been playing around with the module, and the truth is, I can't make it work. I'm not even getting any errors in error.log, the camera just doesn't move.
I followed the instructions in the original post to set up the options in the database. I moved the module to "/usr/share/perl5/ZoneMinder/Control", where the rest of them are, and it is simply not working. Is there something I'm missing?
I'm using ubuntu-server 8.04 and zoneminder 1.23.3
Did you follow the rest of the instructions in that other post?
Control Capability - DCS-6620G:
Main:
Name DCS6620G
Type Remote
Command DCS6620G
Can Wake blank
Can Sleep blank
Can Reset blank
Move:
Can Move checked
Can Move Diagonally not checked
Can Move Mapped checked
Can Move Absolute checked
Can Move Relative checked
Can Move Continuous checked
Pan:
Can Pan checked
Min Pan Range -135
Max Pan Range 135
Min Pan Step 0
Max Pan Step 0
Has Pan Speed blank
Min Pan Speed blank
Max Pan Speed blank
Has Turbo Pan blank
Turbo Pan Speed blank
Tilt:
Can Tilt checked
Min Tilt Range -45
Max Tilt Range 90
Min Tilt Step blank
Max Tilt Step blank
Has Tilt Speed blank
Min Tilt Speed blank
Max Tilt Speed blank
Has Turbo Tilt blank
Zoom:
Can Zoom checked
Can Zoom Absolute blank
Can Zoom Relative blank
Can Zoom Continuous checked
Min Zoom Range 1
Max Zoom Range 10
Min Zoom Step 1
Max Zoom Step 10
Has Zoom Speed blank
Min Zoom Speed 0
Max Zoom Speed 5
Presets:
Has Presets checked
Num Presets 1
Has Home Preset checked
Can Set Presets blank
Look at http://www.zoneminder.com/forums/viewtopic.php?t=12241dashnak wrote:Feel free to contact me whenever you want, I'm very interested in helping getting it to work as soon as possible.
Help
I followed the tutorial from Normando and I worked all right, the only thing I can do is the PAN-Tilt, I have cameras PT7137.Normando wrote:Look at http://www.zoneminder.com/forums/viewtopic.php?t=12241dashnak wrote:Feel free to contact me whenever you want, I'm very interested in helping getting it to work as soon as possible.
Any help please.
Greetings
