Been trying for days to get this working, can you help?
ditalian
Post by ditalian »
Iv tried everything from ubuntu 8 to ubuntu 7.1 to centos to livecd's....
Live cds have always worked...however all of them have there flaws...they either crash after a couple minutes (livecd2008) or after a couple hours they hang to no end (bluecherry)
Currently I have a FRESH install of ubuntu 7.1 I installed all the dependencies needed aswell as a .deb file provided here of zm
Everything installs fine
I run xawtv -c /dev/video0 and i can see video PERFECTLY
through zm......black screen
In the log I get:
Sep 13 16:38:20 camera-server zmwatch[5505]: INF [Restarting capture daemon for Outside, shared memory not valid]
Sep 13 16:38:20 camera-server zmdc[6739]: INF ['zmc -d /dev/video0' started at 08/09/13 16:38:20]
Sep 13 16:38:20 camera-server zmdc[5155]: INF ['zmc -d /dev/video0' starting at 08/09/13 16:38:20, pid = 6739]
Sep 13 16:38:20 camera-server zmc_dvideo0[6739]: INF [Debug Level = 0, Debug Log = <none>]
Sep 13 16:38:20 camera-server zmwatch[5505]: INF ['zmc -d /dev/video0' starting at 08/09/13 16:38:20, pid = 6739]
and iv tried increasing the shmall and shmmax and same deal...
my dmesg output is as follows:
[    8.964650] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    8.964875] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    8.971106] Memory: 246796k/260560k available (2015k kernel code, 13188k reserved, 916k data, 364k init, 0k highmem)
[    8.971121] virtual kernel memory layout:
[    8.971122]     fixmap  : 0xfff4d000 - 0xfffff000   ( 712 kB)
[    8.971123]     pkmap   : 0xff800000 - 0xffc00000   (4096 kB)
[    8.971125]     vmalloc : 0xd0800000 - 0xff7fe000   ( 751 MB)
[    8.971126]     lowmem  : 0xc0000000 - 0xcfe74000   ( 254 MB)
[    8.971127]       .init : 0xc03e3000 - 0xc043e000   ( 364 kB)
[    8.971128]       .data : 0xc02f7d26 - 0xc03dce84   ( 916 kB)
[    8.971130]       .text : 0xc0100000 - 0xc02f7d26   (2015 kB)
[    8.971133] Checking if this processor honours the WP bit even in supervisor mode... Ok.
[    8.971181] SLUB: Genslabs=22, HWalign=64, Order=0-1, MinObjects=4, CPUs=1, Nodes=1
[    9.051072] Calibrating delay using timer specific routine.. 4391.29 BogoMIPS (lpj=8782580)
[    9.051110] Security Framework v1.0.0 initialized
[    9.051121] SELinux:  Disabled at boot.
[    9.051138] Mount-cache hash table entries: 512
[    9.051355] CPU: After generic identify, caps: bfebfbff 00000000 00000000 00000000 00004400 00000000 00000000
[    9.051374] CPU: Trace cache: 12K uops, L1 D cache: 8K
[    9.051378] CPU: L2 cache: 128K
[    9.051381] CPU: Hyper-Threading is disabled
[    9.051384] CPU: After all inits, caps: bfebfbff 00000000 00000000 0000b080 00004400 00000000 00000000
[    9.051401] Compat vDSO mapped to ffffe000.
[    9.051423] Checking 'hlt' instruction... OK.
[    9.067209] SMP alternatives: switching to UP code
[    9.067636] Freeing SMP alternatives: 11k freed
[    9.068076] Early unpacking initramfs... done
[    9.462865] ACPI: Core revision 20070126
[    9.474846] ACPI: Looking for DSDT in initramfs... error, file /DSDT.aml not found.
[    9.498669] CPU0: Intel(R) Celeron(R) CPU 2.20GHz stepping 09
[    9.498722] Total of 1 processors activated (4391.29 BogoMIPS).
[    9.498868] ENABLING IO-APIC IRQs
[    9.499078] ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
[    9.646159] Brought up 1 CPUs
[    9.646402] Booting paravirtualized kernel on bare hardware
[    9.646513] Time: 20:23:53  Date: 08/13/108
[    9.646561] NET: Registered protocol family 16
[    9.646792] EISA bus registered
[    9.646820] ACPI: bus type pci registered
[    9.647884] PCI: PCI BIOS revision 2.10 entry at 0xfbc7f, last bus=1
[    9.647887] PCI: Using configuration type 1
[    9.647890] Setting up standard PCI resources
[    9.654195] ACPI: EC: Look up EC in DSDT
[    9.680007] ACPI: Interpreter enabled
[    9.680016] ACPI: (supports S0 S1 S3 S4 S5)
[    9.680053] ACPI: Using IOAPIC for interrupt routing
[    9.718576] ACPI: PCI Root Bridge [PCI0] (0000:00)
[    9.718600] PCI: Probing PCI hardware (bus 00)
[    9.718946] * The chipset may have PM-Timer Bug. Due to workarounds for a bug,
[    9.718949] * this clock source is slow. If you are sure your timer does not have
[    9.718950] * this bug, please use "acpi_pm_good" to disable the workaround
[    9.719002] PCI quirk: region 0800-087f claimed by ICH4 ACPI/GPIO/TCO
[    9.719006] PCI quirk: region 0880-08bf claimed by ICH4 GPIO
[    9.719480] PCI: Transparent bridge - 0000:00:1e.0
[    9.719520] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[    9.720081] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[    9.811294] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
[    9.811659] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 *4 5 6 7 9 10 11 12 15)
[    9.812018] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[    9.812380] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[    9.812739] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[    9.813101] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[    9.813457] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[    9.813844] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[    9.814137] Linux Plug and Play Support v0.97 (c) Adam Belay
[    9.814173] pnp: PnP ACPI init
[    9.814194] ACPI: bus type pnp registered
[    9.836633] pnp: PnP ACPI: found 10 devices
[    9.836640] ACPI: ACPI bus type pnp unregistered
[    9.836647] PnPBIOS: Disabled by ACPI PNP
[    9.836797] PCI: Using ACPI for IRQ routing
[    9.836804] PCI: If a device doesn't work, try "pci=routeirq".  If it helps, post a report
[    9.840458] NET: Registered protocol family 8
[    9.840462] NET: Registered protocol family 20
[    9.840653] pnp: 00:00: iomem range 0x0-0x9ffff could not be reserved
[    9.840659] pnp: 00:00: iomem range 0x100000-0xffffff could not be reserved
[    9.840663] pnp: 00:00: iomem range 0x1000000-0xfe73fff could not be reserved
[    9.840666] pnp: 00:00: iomem range 0xc0000-0xfffff could not be reserved
[    9.840684] pnp: 00:09: ioport range 0x800-0x85f has been reserved
[    9.840688] pnp: 00:09: ioport range 0xc00-0xc7f has been reserved
[    9.840691] pnp: 00:09: ioport range 0x860-0x8ff could not be reserved
[    9.841732] Time: tsc clocksource has been installed.
[    9.871850] PCI: Bridge: 0000:00:1e.0
[    9.871853]   IO window: disabled.
[    9.871861]   MEM window: fe900000-feafffff
[    9.871867]   PREFETCH window: f8000000-f80fffff
[    9.871884] PCI: Setting latency timer of device 0000:00:1e.0 to 64
[    9.871908] NET: Registered protocol family 2
[    9.909684] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[    9.909767] TCP established hash table entries: 8192 (order: 4, 98304 bytes)
[    9.909874] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    9.909976] TCP: Hash tables configured (established 8192 bind 8192)
[    9.909983] TCP reno registered
[    9.921824] checking if image is initramfs... it is
[   10.372834] Switched to high resolution mode on CPU 0
[   10.675512] Freeing initrd memory: 7057k freed
[   10.675724] Simple Boot Flag value 0x87 read from CMOS RAM was invalid
[   10.675729] Simple Boot Flag at 0x7a set to 0x1
[   10.676436] audit: initializing netlink socket (disabled)
[   10.676461] audit(1221337433.268:1): initialized
[   10.682885] VFS: Disk quotas dquot_6.5.1
[   10.683062] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[   10.683346] io scheduler noop registered
[   10.683351] io scheduler anticipatory registered
[   10.683354] io scheduler deadline registered
[   10.683404] io scheduler cfq registered (default)
[   10.683427] Boot video device is 0000:00:02.0
[   10.683881] isapnp: Scanning for PnP cards...
[   11.037615] isapnp: No Plug & Play device found
[   11.177599] Real Time Clock Driver v1.12ac
[   11.177843] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[   11.181963] RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
[   11.182316] input: Macintosh mouse button emulation as /class/input/input0
[   11.182588] PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
[   11.185579] serio: i8042 KBD port at 0x60,0x64 irq 1
[   11.185591] serio: i8042 AUX port at 0x60,0x64 irq 12
[   11.186167] mice: PS/2 mouse device common for all mice
[   11.186543] EISA: Probing bus 0 at eisa.0
[   11.186587] EISA: Detected 0 cards.
[   11.186750] TCP cubic registered
[   11.186784] NET: Registered protocol family 1
[   11.186828] Using IPI No-Shortcut mode
[   11.187126]   Magic number: 8:938:396
[   11.188027] Freeing unused kernel memory: 364k freed
[   11.235390] input: AT Translated Set 2 keyboard as /class/input/input1
[   12.686511] AppArmor: AppArmor initialized<5>audit(1221337435.268:2):  type=1505 info="AppArmor initialized" pid=1153
[   12.797041] fuse init (API version 7.8)
[   12.807191] Failure registering capabilities with primary security module.
[   12.921854] ACPI Exception (processor_core-0783): AE_NOT_FOUND, Processor Device is not present [20070126]
[   23.643534] SCSI subsystem initialized
[   23.652184] libata version 2.21 loaded.
[   23.654685] ata_piix 0000:00:1f.1: version 2.11
[   23.654717] ACPI: PCI Interrupt 0000:00:1f.1[A] -> GSI 18 (level, low) -> IRQ 16
[   23.654778] PCI: Setting latency timer of device 0000:00:1f.1 to 64
[   23.654947] scsi0 : ata_piix
[   23.655059] scsi1 : ata_piix
[   23.655129] ata1: PATA max UDMA/100 cmd 0x000101f0 ctl 0x000103f6 bmdma 0x0001ffa0 irq 14
[   23.655135] ata2: PATA max UDMA/100 cmd 0x00010170 ctl 0x00010376 bmdma 0x0001ffa8 irq 15
[   23.817653] ata1.00: ATA-7: Maxtor 2F040L0, VAM51JJ0, max UDMA/133
[   23.817659] ata1.00: 80293248 sectors, multi 8: LBA
[   23.833592] ata1.00: configured for UDMA/100
[   24.145016] ata2.00: ATAPI: Lite-On LTN486S 48x Max, YDS6, max UDMA/33
[   24.308725] ata2.00: configured for UDMA/33
[   24.316403] scsi 0:0:0:0: Direct-Access     ATA      Maxtor 2F040L0   VAM5 PQ: 0 ANSI: 5
[   24.316930] scsi 1:0:0:0: CD-ROM            Lite-On  LTN486S 48x Max  YDS6 PQ: 0 ANSI: 5
[   24.320781] b44.c:v1.01 (Jun 16, 2006)
[   24.320816] ACPI: PCI Interrupt 0000:01:09.0[A] -> GSI 17 (level, low) -> IRQ 17
[   24.324389] eth0: Broadcom 4400 10/100BaseT Ethernet 00:0b:db:bc:b2:60
[   24.516290] sr0: scsi3-mmc drive: 48x/48x cd/rw xa/form2 cdda tray
[   24.516299] Uniform CD-ROM driver Revision: 3.20
[   24.516399] sr 1:0:0:0: Attached scsi CD-ROM sr0
[   24.523222] scsi 0:0:0:0: Attached scsi generic sg0 type 0
[   24.523266] sr 1:0:0:0: Attached scsi generic sg1 type 5
[   24.771621] sd 0:0:0:0: [sda] 80293248 512-byte hardware sectors (41110 MB)
[   24.775567] sd 0:0:0:0: [sda] Write Protect is off
[   24.775572] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[   24.783550] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   24.791545] sd 0:0:0:0: [sda] 80293248 512-byte hardware sectors (41110 MB)
[   24.795526] sd 0:0:0:0: [sda] Write Protect is off
[   24.795531] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[   24.803517] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   24.803528]  sda: sda1 sda2 <sda5>
[   24.860761] sd 0:0:0:0: [sda] Attached SCSI disk
[   26.902695] Attempting manual resume
[   26.902702] swsusp: Resume From Partition 8:5
[   26.902705] PM: Checking swsusp image.
[   26.999666] PM: Resume from disk failed.
[   27.622670] kjournald starting.  Commit interval 5 seconds
[   27.622699] EXT3-fs: mounted filesystem with ordered data mode.
[   53.081071] Linux agpgart interface v0.102 (c) Dave Jones
[   53.147526] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[   53.150494] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[   53.175636] agpgart: Detected an Intel 830M Chipset.
[   53.175755] agpgart: Detected 892K stolen memory.
[   53.194180] agpgart: AGP aperture is 128M @ 0xe8000000
[   53.194213] i810_smbus 0000:00:02.0: i810/i815 i2c device found.
[   53.425373] intel_rng: FWH not detected
[   53.465176] iTCO_vendor_support: vendor-support=0
[   53.466865] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.01 (21-Jan-2007)
[   53.467035] iTCO_wdt: Found a ICH4 TCO device (Version=1, TCOBASE=0x0860)
[   53.467144] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[   53.730521] input: PC Speaker as /class/input/input2
[   53.770731] Linux video capture interface: v2.00
[   53.838528] bttv: driver version 0.9.17 loaded
[   53.838533] bttv: using 8 buffers with 2080k (520 pages) each for capture
[   53.838662] bttv: Bt8xx card found (0).
[   53.838700] ACPI: PCI Interrupt 0000:01:04.0[A] -> GSI 16 (level, low) -> IRQ 18
[   53.838716] bttv0: Bt878 (rev 17) at 0000:01:04.0, irq: 18, latency: 64, mmio: 0xf8001000
[   53.838736] bttv0: detected: Provideo PV143A [card=105], PCI subsystem ID is aa00:1430
[   53.838740] bttv0: using: ProVideo PV143 [card=105,autodetected]
[   53.838780] bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
[   53.839257] bttv0: using tuner=-1
[   53.839263] bttv0: i2c: checking for TDA9875 @ 0xb0... <4>logips2pp: Detected unknown logitech mouse model 95
[   54.125231] not found
[   54.125241] bttv0: i2c: checking for TDA7432 @ 0x8a... not found
[   54.156549] bttv0: i2c: checking for TDA9887 @ 0x86... not found
[   54.157599] bttv0: registered device video0
[   54.158031] bttv0: registered device vbi0
[   54.158061] bttv0: PLL: 28636363 => 35468950 .. ok
[   54.206577] bt878: AUDIO driver version 0.0.0 loaded
[   54.207477] bt878: Bt878 AUDIO function found (0).
[   54.207509] ACPI: PCI Interrupt 0000:01:04.1[A] -> GSI 16 (level, low) -> IRQ 18
[   54.207518] bt878_probe: card id=[0x1430aa00], Unknown card.
[   54.207520] Exiting..
[   54.207525] ACPI: PCI interrupt for device 0000:01:04.1 disabled
[   54.207533] bt878: probe of 0000:01:04.1 failed with error -22
[   54.321524] input: ImExPS/2 Logitech Explorer Mouse as /class/input/input3
[   54.327335] parport_pc 00:08: reported by Plug and Play ACPI
[   54.327393] parport0: PC-style at 0x378 (0x778), irq 7, using FIFO [PCSPP,TRISTATE,COMPAT,ECP]
[   55.442543] loop: module loaded
[   55.472221] lp0: using parport0 (interrupt-driven).
[   55.598656] Adding 746980k swap on /dev/sda5.  Priority:-1 extents:1 across:746980k
[   56.104959] EXT3 FS on sda1, internal journal
[   57.756972] No dock devices found.
[   57.970851] input: Power Button (FF) as /class/input/input4
[   57.978368] ACPI: Power Button (FF) [PWRF]
[   58.030902] input: Power Button (CM) as /class/input/input5
[   58.038313] ACPI: Power Button (CM) [VBTN]
[   60.660913] NET: Registered protocol family 10
[   60.661497] lo: Disabled Privacy Extensions
[   60.662749] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   61.771621] ppdev: user-space parallel port driver
[   62.007742] audit(1221337485.470:3):  type=1503 operation="inode_permission" requested_mask="a" denied_mask="a" name="/dev/tty" pid=4590 profile="/usr/sbin/cupsd"
[   63.248276] b44: eth0: Link is up at 100 Mbps, full duplex.
[   63.248283] b44: eth0: Flow control is off for TX and off for RX.
[   63.248570] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   65.235057] apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16ac)
[   65.235065] apm: overridden by ACPI.
[   77.694243] Failure registering capabilities with primary security module.
[   78.063761] Bluetooth: Core ver 2.11
[   78.064238] NET: Registered protocol family 31
[   78.064248] Bluetooth: HCI device and connection manager initialized
[   78.064253] Bluetooth: HCI socket layer initialized
[   78.095323] Bluetooth: L2CAP ver 2.8
[   78.095333] Bluetooth: L2CAP socket layer initialized
[   78.103838] Bluetooth: RFCOMM socket layer initialized
[   78.104243] Bluetooth: RFCOMM TTY layer initialized
[   78.104253] Bluetooth: RFCOMM ver 1.8
[   83.427195] [drm] Initialized drm 1.1.0 20060810
[   83.435856] ACPI: PCI Interrupt 0000:00:02.0[A] -> GSI 16 (level, low) -> IRQ 18
[   83.437235] [drm] Initialized i915 1.6.0 20060119 on minor 0
[   85.642805] NET: Registered protocol family 17
[  200.407221] eth0: no IPv6 routers present
[  329.345715] bttv0: PLL can sleep, using XTAL (28636363).
I just dont understand how xawtv views it fine and zm just is always black? What could I be doing wrong?
Oh also I went into the BIOS and disabled a bunch of stuff hopeing maybe it was an IRQ issue...however again...the card works fine in xawtv
Please if anyone can, give me a hand
cordel
Post by cordel »
Have you tried turning on debug, upping the level and checking zmdc.log, messages, and the apache error_log?
There will be something more descriptive other than "shared memory not valid" which only means that for some reason zmc was unable to capture from the device and didn't put anything in shared memory.
ditalian
Post by ditalian »
never saw the extra debug option
ended up being a permission problem on /dev/video0
thanks for the help!
