Nice, low cost 4 port card w/4 BT878
Hi All,
Pro-video has a nice 4-port card that has 4 BT 878's on it. It's model number PV149A. I ordered direct from the company in Taiwan. It was delivered via EMS postal service -- price was very right. Work fine with ZM.
No; sorry - I sure don't. All my communications with them including the order process were handled via email.
Even tho I am totally happy with my card, I would not buy anything from a company that would not do me the courtesy of answering my emails. If they're too busy to answer me they darn sure don't need my business.......
- Carbide_tipped
any idea where/how to get the card ?
i would really like the 149 card, but i can't seem to find a reseller in the us, or be able to contact the maker in taiwan.
Rick, and "carbide_tipped" where did you get it, do you have a contact (email address or anyhting)
Thanks.
Thanks.
- Carbide_tipped
http://www.supercircuits.com for the pv-140. I'm not 100% happy with it. But it works fine. I think it was about $120.00
I think you will be better off getting the GrandTec Grand X-Guard 4P card. http://www.grandtec.com/xguard.htm It's cheaper. $99.00 I never use it but I guess it works with zomeminder from this post. http://www.zoneminder.com/forums/viewtopic.php?t=3285
I'm in control till it's out of control
GrandTec Grand X-Guard 4P card and ZM - Works Fine
I use the GrandTec Grand X-Guard 4P card with ZoneMinder. Absolutely no problems. Fully plug and pray with the OS - no device files to create etc. I get about 2.2fps per camera with all 4 ports are occupied. I'm using ZoneMinder LiveCD v1.19.1. I would definitely recommend this card, especially if you can source it locally and its cheaper than the PV series cards.
PV153
The current Provideo card with 4 chips is the PV153. They have 4 video and 4 audio channels. They were $110 each, which ended up being $150 each after shipping and wire transfer fees. They suggested emailing my CC#, but I will not email such a valuable number, nor will I send it to a foreign company. If only they would accept paypal...
I have two that are being shipped to me, and will report on how they work.
Update
I have received the cards, which took a week to get here from Taiwan. I will be testing them once I find a machine to run them as I have not ordered the components.
A few notes...
They have 4 models of each card (A,B,C,D). They are functionally identical, although you cannot put two of the same letter in one computer.
There is no visible difference between my A card and B card as far as I can tell. I have emailed, asking how I can tell the difference.
They have 2 VGA ports, and a cable that contains 4 audio and 4 video inputs. One of the VGA ports is mentioned as the input, the other port is ignored in the manual.
They have four 10 pin connectors internally, marked as OP (output?) 1-4, although they are not mentioned in the manual.
They have two jumper points, one of which is mentioned in the manual as the watchdog port. However, the other one is not mentioned.
There is one 34 pin connector mentioned in the manual as the GPIO port, although its function is not clear from the manual.
A few notes...
