pico2000 card and size of images????
angelhod
Post by angelhod »
hi i've got card like pico2000
module.conf is set to card 77
i got 3 cameras connected and when all of them got sieze
240x240 everything is fine but when i changed one to 480x320
2 others got f*** up like :
http://www.fotosik.pl/pokaz_obrazek/b7e ... aadd4.html
some plz help me... or it is only the problem of the card and this
card cant do better?[/quote]
TrOjAn
Post by TrOjAn »
If its the single chip card then you will have to keep the sizes UNDER 320 x 240, it just cannot cope with huge sizes for more than one camera.
TrOjAn
angelhod
Post by angelhod »
ehhh
i cant do more then 240x240 .......
damnit i thought that this card is almost the same with Kodicom 4400 except
FPS......................
angelhod
Post by angelhod »
anyway thank You for your reply Tojan
cordel
Post by cordel »
On each bt878 device, all of its inputs must match size and palette. It is unable to change on the fly that quickly. bt878 supports up to 640x480 which is interlaced of coarse.
TrOjAn
Post by TrOjAn »
Ahhh now thats interesting... I never thought to do them ALL.. just tried 352 x 288 on all cameras and its working... I am going to try going up again to 384 x 288 and if that works I may try 640 x 480
TrOjAn
angelhod
Post by angelhod »
OMFG
Cordel You are the best of the best!!!!!!
now its working fine...
TrOjAn
Post by TrOjAn »
Managed to get 384 x 288 but any higher and it loses the picture, broken image in corner.. o well, Im happy with it for now.
TrOjAn
angelhod
Post by angelhod »
now got 3 times 640x480 :) :)
TrOjAn
Post by TrOjAn »
angelhod wrote:now got 3 times 640x480 :) :)
Now dont show off :D can you tell me how much memory your pc has installed? I am thinking I may be low on memory.. I use the pico2000 1 chip 4 input pci card and I am unable to get that resolution.
Cheers, TrOjAn
angelhod
Post by angelhod »
haha
well first i had pIII 900MHz 256mb ram
and it was warking almost 3 years with kodicom4400 but CPU was almost all the time 80-95% busy...
now after kodicom brok down... i bought that pico2000 or whatever it is...
and changed a computer for these camers.... now it is Athlon XP 1600 or 1700 and only 512mb of ram ;)
and cpu usage is around 62% but now everything goes really smoth with all i do on this machine.... i am planning to add one more camra.....
how much memory u got?
angelhod
Post by angelhod »
maybe u got one monitor rotated?
TrOjAn
Post by TrOjAn »
Nope nothing rotated, 764 mb memory on a dedicated ubuntu machine.. running nothing else.
Weird huh? O well.. 384 x 288 aint too bad :)
TrOjAn
angelhod
Post by angelhod »
sure it is bad....
maybe the u've choosen wrong card type.... my friend had same problem ....
u sure u've set the card to 77?
