I am attempting to boot the LiveCD, but I am having trouble. When it goes to activate the swap partition, it kernel panics.
I don't know why it's attempting to mount swap, because I have not even had a chance to partition the drive.
Is there some special line I can type in at trhe boot prompt to do an install instead of attempting to boot the live CD?
Thanks,
-- Terry
Kernel Panic on boot
Before install the CD you need to get the Linux System on LiveCD working.. the install procedure is simply a script that copy the current working system on your HD.
To solve the mount swap problem: I don't know if will work but you can try with "livecd noswap"
some link to BOOTCODES:
http://www.elltel.net/melins/livecd/iso ... .BOOTCODES
http://www.zoneminder.com/forums/viewto ... =bootcodes
here there is a reference to the "noswap" option (morphix):
http://am.xs4all.nl/phpwiki/index.php/M ... ootOptions
regards,
davide.
regards,
davide.
I would also point out that the unstable scsi module "gotcha" often shows up about the time the swap message appears on the screen. So, once again:
Try booting with "livecd noscsi"
And I am so happy to report that this will be a far less common problem with the next version of livecd as the worst offending modules are no longer included.
Ross
Ross
A little more help with lilo
Ok, don't flame me too bad. I really have never had to pass any pramaters off to lilo other than booting to single user mode. Exactly what do I need to type in at the lilo prompt. There does not seem to be a label for "livecd"
Sorry for being so dense and thanks in advance for your advice.
--Terry
--Terry
In the case of the livecd the bootloader is isolinux rather than lilo. Just type at the bootprompt "livecd noscsi" without the quotes.
Some of the bootcodes in the README.BOOTCODES file will not work correctly with version 1.19.1 due to kernel limitation. Again this is greatly improved in the upcoming version. But at least the noscsi, noswap, nousb bootcodes do what they are supposed to.
Ross
Ross
Got it working!
Thaks folks! I got it working. I had a bad CD-ROM drive that was giving me fits.
I also had to boot off of the older 1.17 CD, partition the drive and format the filesystems and then I could boot the newer 1.19 CD. I think I was attempting to make it harder than it should be
Thanks for all your help!
-- Terry
-- Terry
