Perl Question
RobinQi
Perl Question
Post by RobinQi »
Hi! All: I just upgraded to v1.23.3. Then zmfilter.pl failed to work. After investigation I found the issue is zmfilter.pl cannot locate PHP:Serialization. I did install PHP, but it's in a local directory. I thought by putting the local directory into $PERLLIB and $PERL5LIB should make it visible to zmfilter.pl. However I noticed the first line in zmfilter.pl is:
#!/usr/bin/perl -wT
That -T is the one caused the trouble. Somehow when I specify -T, perl doesnot search $PERLLIB or $PERL5LIB. If I take it out, zmfilter.pl runs smoothly.
For now I have to copy the PHP:Serialization module to a system perl directory.
I am no perl expert. Just wondering, can I take that -T out? What does it do?
kevin_robson
Post by kevin_robson »
I'm no expert either, but I think the term to google is 'perl tainting'
I'm sure someone more knowledgable will provide further info
cordel
Post by cordel »
RobinQi
Post by RobinQi »
Thanks. it's a security feature.
