problem with one channel on a 8-port card, [screenshot]
gregorsk
Post by gregorsk »
Hi everyone,
I've dug into this problem and haven't found anything wrong, no hints in dmesg, or messages. The screen shot, is of the camera to the back_door, the image is present but its like it is overlaped somehow.
http://www.lsc-group.phys.uwm.edu/~gske ... oblem.jpeg
I've switched cameras on that particular port /dev/video3(1) and the screwed up image stays. The camera still records events, but the images it records are in the screwed up state.
Does anyone know where I should start looking?
Thanks in advance,
PS I tried googling the problem and looking in the forums , but didn't find anything remotely close
[code]
Oct 8 16:41:24 surveillance zmc_dvideo0[15803]: INF [back_door: 36000 - Capturing at 5.88 fps]
Oct 8 16:41:54 surveillance zma_m2[29029]: INF [back_door: 297000 - Processing at 6.02 fps]
Oct 8 16:42:08 surveillance zma_m2[29029]: INF [back_door: 297074 - Gone into alarm state]
Oct 8 16:42:08 surveillance zma_m2[29029]: INF [back_door: 297074 - Creating new event 429649]
Oct 8 16:42:10 surveillance zma_m2[29029]: INF [back_door: 297089 - Gone into alert state]
Oct 8 16:42:11 surveillance zma_m2[29029]: INF [back_door: 297093 - Gone back into alarm state]
Oct 8 16:42:11 surveillance zma_m2[29029]: INF [back_door: 297096 - Gone into alert state]
Oct 8 16:42:13 surveillance zma_m2[29029]: INF [back_door: 297106 - Left alarm state (429649) - 42(18) images]
Oct 8 16:42:15 surveillance zma_m7[29051]: INF [office_door: 408922 - Gone into alarm state]
Oct 8 16:42:15 surveillance zma_m7[29051]: INF [office_door: 408922 - Creating new event 429650]
Oct 8 16:42:17 surveillance zma_m7[29051]: INF [office_door: 408931 - Gone into alert state]
Oct 8 16:42:18 surveillance zma_m7[29051]: INF [office_door: 408941 - Left alarm state (429650) - 29(9) images]
[/code]
cordel
Post by cordel »
Are all your inputs on /dev/video3 set to the same format, size and palette?
Have you restarted ZM since making any changes to the monitors?
gregorsk
Post by gregorsk »
Yes, all 8 camera's are all set to NTSC, RGB24, and 480x320
Yes, I've restarted ZM a couple times and I still have this problem.
I probably should note, I saw this problem when I was running BlueCherry Ubuntu a couple months ago, before I switched to Centos 5.2 and haven't seen it for like 6 months, and now its cropped up again.
Thanks for the questions,
Greg
cordel
Post by cordel »
Any errors in dmesg?
What are your interrupt assignments?
Lee Sharp
Post by Lee Sharp »
Put a heat sink on those bt878 chips. :) Seriously, an overheating chip can cause this. As can a shared IRQ... Any new hardware?
gregorsk
Post by gregorsk »
There's nothing out of the ordinary in dmesgs, not that it would point to /dev/video3 or anything.
<snip>
CPU0
0: 279855899 IO-APIC-edge timer
1: 8 IO-APIC-edge i8042
6: 6 IO-APIC-edge floppy
7: 0 IO-APIC-edge parport0
8: 1 IO-APIC-edge rtc
9: 0 IO-APIC-level acpi
12: 4 IO-APIC-edge i8042
14: 2481579 IO-APIC-edge ide0
169: 24990748 IO-APIC-level bttv2
177: 0 IO-APIC-level ohci_hcd:usb1
185: 0 IO-APIC-level ohci_hcd:usb2
193: 0 IO-APIC-level ohci_hcd:usb3
201: 0 IO-APIC-level ehci_hcd:usb4
209: 30965688 IO-APIC-level sata_sis, bttv3
217: 24067972 IO-APIC-level bttv0, SiS SI7012
225: 35708088 IO-APIC-level bttv1, eth0
NMI: 0
LOC: 279870176
ERR: 0
MIS: 0
</snip>
cordel
Post by cordel »
For dmesg, are you looking at /var/log/dmesg or are you running dmesg from the command line.
The two are not the same. dmesg in your log folder is only at time of bootup. If you do a dmesg from the command line it will show everything from bootup till current.
The one you should be looking at is the dmesg from the command line.
gregorsk
Post by gregorsk »
Yep, I always check that one.
Have anyone seen this problem before?
I can't say for sure, but I think a guy that guy that posted about putting a heat sink on the card was probably right. The guy who brought the box, put it in a wooden box for security reasons; its gotta be at least 100+ degree's in there all the time.
Though, does anyone have any other thoughts or ideas?
Cheers,
Greg
[quote="cordel"]For dmesg, are you looking at /var/log/dmesg or are you running dmesg from the command line.
The one you should be looking at is the dmesg from the command line.[/quote]
xyz
Post by xyz »
What will xawtv expose when used at the same source? Is the card itself OK? In case you have X-less computer, it's still possible to record images from /dev/video*, use something like: ffmpeg -s 320x240 -vd /dev/video0 test.mpg.
I have an old Boeder capture card (without tuner) which worked fine 8 yrs ago on a 200MHz computer but which shows approx the same unsync pic while used with new motherboards. Have tried several video sources - no sync anyway. I suspect the card needs recapping (changing electrolytic capacitors on the board).
Other ideas - feeding your video via incorrect S-VHS connector, having exchanged signal and ground wires, 50/60Hz will somehow find it's way into the signal path (via PSU)...
