Windows Live Viewer..27-11-05 Now Complete Frontend for ZM!!
emotionaltrout
Post by emotionaltrout »
Not too sure if this post is alive anymore but need to pick someone's brains....
Have zm and zm4ms working together but on the live view in zm4ms i have a problem with images.....it looks like it's getting the info but can't show the image:
http://www.badongo.com/pic/4467447
Any ideas?
jameswilson
Post by jameswilson »
its not getting images.
its either a path problem / issue or a login permission issue. Have you created a user that matches in both zm4ms and zm.
James Wilson
emotionaltrout
Hi, thanks for quick response.
I have read through this whole post and done everything I could do.
I have given both zm and zm4ms the same logins with the same passwords.
The cameras I'm using are Axis IP's if that helps and they all have viewer accounts setup for them.
I've tried countless ip paths but no success.
jameswilson
the monitor ip should be just that, the ip of your zm server.
You may need to monitor the path but only if you have a non std install. zm4ms is designed to work out the box with ross's live cd.
If you post the full url to view a static image i can see if your path is non std.
James
James Wilson
iamnacho
ZM_EVENT_IMAGE_DIGITS >4
Post by iamnacho »
James,
I'm using >4 digits in my ZM. Is it possible to get ZM4MS to go higher than 3? (I'm trying to use 5)
Thanks!
jameswilson
it can do 4, but im not sure it does 5. Id have to look at the code.
Im assuming it doesnt work if you put 5 in the digit setting.
It was modified on request for 4, but i dont understand a reason to use anything other than 3, it will work fine on both the web i/f and zm4ms with 3.
Unless there is a reason im not aware off.
James
James Wilson
iamnacho
Post by iamnacho »
[quote="jameswilson"]
[/quote]
That is right, it doesn't work if I put 5 in (per my apache logs it looks like it reverts back to 1).
I'm not sure if my logic was flawed on this one or not, but I am capturing at 30fps on some of my cameras. I figured 4 digits = 10000 unique numbers. So (10000/30fps)/60seconds = 5.5 minutes of record time @ 30fps before I run out of available numbers. That's Why I set the number to 5 in my ZM. I haven't (knowingly) seen any events go for that long, but I wanted to be prepared just in case. Is my logic flawed?
Thanks for your quick response!
jameswilson
all the 3 digit does is atart at 001
4 digit starts at 0001
but there is no limit to the number of images on either setting so
if you had 100000 images per event with 3 digit numbering
001
999
1000
9999
10000
99999
100000
999999
and beyond
only required IMO so as can sort in order on a folder view, not for web UI or zm4ms UI
James Wilson
Normando
Post by Normando »
Thanks James for this great contrib.
Is there a way to change the mysql port at events tab? because I use a nonstandard port.
Thank you.
jameswilson
i could look into it, but i use the vb.net mysql lib, and i dont have to declare the port, so i will have to read the docs to see if this is an option.
Agreed it would be useful though
James Wilson
alecano23
36 Cams view in Full screen does not appear
Post by alecano23 »
Hello, I cant enable the 36 way view on fullscreen with toolstrip button, only have for 16 cams and no more. Why the 36 view cam does not appear in full screen mode?? I have ZM4MS 2.89
jameswilson
the full screen view only does 16 cams as it was never written to do more.
I can add that into a future release.
James
James Wilson
assuncao
Post by assuncao »
It's a open source client?
jameswilson
no
James Wilson
alexc
Post by alexc »
Hello
Thanks for your software
I use the fullscreen mode for view my cams. But I have more than 16 cams.
I just ask if you predict to add a 32 cams view in full screen, or switch automatically 2 screen (every ? seconds)
Sorry for my english
