I spent some time analyzing the remote commands used by the AirLink101 747/747W (details here) and put together a module for the PTZ functions for ZM 1.23.x and 1.24.x which can be downloaded here.
This camera appears to be an OEM version of the Fitivision CS-130A/CS-131A which is essentially the same as the TrendNet TV-IP410/TV-IP410W, which share the same control commands as the Airlink 777/777W and TrendNet TV-IP422/422W. If anyone has one of these cameras and can confirm/deny compatibility, please do!
Install this module with the rest of your ZoneMinder Control Perl libraries (mine are in /usr/lib/perl5/site_perl/5.8.5/ZoneMinder/Control):
Under control tab of your monitor:
Controllable: check
Control Address: username:password@mycamip
Then click on the "Edit" link right of "Control Type" to create the new control module definition.
At the new window click at the "Create New Control" button.
Main tab:
Name: AirLink SkyIPCam 7xx
Type: Remote
Protocol: SkyIPCam7xx
Can Reset: Check
Move tab:
Can Move: check
Can Move Mapped: check
Can Move Relative: check
Pan tab:
Can Pan: check
Tilt tab:
Can Tilt: check
Presets tab:
Has Presets: check
Num Presets: 8
Has Home Preset: check
Can Set Presets: check
At your monitor window, refresh and select from the pull-down list "AirLink SkyIPCam 7xx" at the "Control Type" field.
