Im trying to get Signal Loss detection working, and it seems to be doing so pretty well because in my syslog I get
zma_m7[28696]: WAR [Signal: Lost]
and
zma_m7[28696]: WAR [Signal: Reacquired]
messages fine, but, only occasionally do these show up as an event in the console.
What could be stopping them getting turned into events as a rule (rather than an exception?)
Thanks.
Signal Lost & Reacquired warnings not showing up as even
Ok here is my patch.
Most of the changes are actually to add the functionality that instead of comparing one pixel with the pre-defined colour in the config page of each monitor, it compares two randomly selected pixels (and if ZM_SIGNAL_CHECK_POINTS of them are the same, a signal change is registered)
Working like a charm.
--- ../../ZM-1.23.3/src/zm_monitor.cpp 2008-03-14 00:36:12.000000000 +1100
+++ zm_monitor.cpp 2008-10-26 23:22:49.201039574 +1100
@@ -879,9 +879,14 @@
for ( int i = 0; i < config.signal_check_points; i++ )
- int index = (rand()*pixels)/RAND_MAX;
+ /* int index = (rand()*pixels)/RAND_MAX; */
+ float foo = ((float) rand()) / ((float) RAND_MAX);
+ float foo1 = ((float) rand())/ ((float) RAND_MAX);
+ int index = pixels/3 + (int)((float) pixels * foo / 3.0f);
+ int index1= pixels/3 + (int)((float) pixels * foo1 / 3.0f);
const unsigned char *ptr = buffer+(index*colours);
- if ( (RED(ptr) != red_val) || (GREEN(ptr) != green_val) || (BLUE(ptr) != blue_val) )
+ const unsigned char *ptr1 = buffer+(index1*colours);
+ if ( (RED(ptr) != RED(ptr1) ) || (GREEN(ptr) != GREEN(ptr1) ) || (BLUE(ptr) != BLUE(ptr1) ) )
return( true );
@@ -1041,6 +1046,7 @@
else
signal_text = "Signal: Reacquired";
Warning(( signal_text ));
+ alarm_frame_count = 1;
if ( event )
closeEvent();
