Hello folks,
I'm trying to install ZM 1.23 on a Clarkconnect box. I've installed all the packages required (including mysql-devel) but when I'm trying to configure it says configure: error: zm requires libmysqlclient.a. The required file is installed in /usr/lib/mysql and the full command line is
./configure --with-mysql=/usr/lib/mysql --with-ffmpeg=/usr/local --with-webdir=/var/www/html --with-cgidir=/var/www/cgi-bin ZM_SSL_LIB='openssl'
Any idea?
Thanks!
Help with "libmysqlclient.a"
Re: Help with "libmysqlclient.a"
I got this error whilst installing 64 bit centos and over came it with this doco found in centos install howto. You just add the follwoing text to the end of your command above.NeaVasile wrote:Hello folks,
Any idea?
Thanks!
HTH Brad
