When use zoneminder with both card I have bad picture, some extra line. see picture
When I use only one card evrything is all right.
My system is Debian lenny/sid, kernel 2.6.26-1-686-bigmem, CPU Pentium D 3.40GHz 1,5GB RAM
monitor:~# cat /proc/interrupts
CPU0 CPU1
0: 64 0 IO-APIC-edge timer
1: 16 0 IO-APIC-edge i8042
8: 28 0 IO-APIC-edge rtc0
9: 0 0 IO-APIC-fasteoi acpi
14: 0 0 IO-APIC-edge ide0
16: 898511 0 IO-APIC-fasteoi uhci_hcd:usb4, bttv11, bttv15
17: 894989 0 IO-APIC-fasteoi bttv10, bttv14
18: 898851 0 IO-APIC-fasteoi uhci_hcd:usb3, bttv8, bttv12
19: 908946 0 IO-APIC-fasteoi uhci_hcd:usb2, ata_piix, bttv9, bttv13
20: 899465 0 IO-APIC-fasteoi bttv2, bttv6
21: 899471 0 IO-APIC-fasteoi bttv1, bttv5
22: 899548 0 IO-APIC-fasteoi bttv0, bttv4
23: 899278 0 IO-APIC-fasteoi uhci_hcd:usb1, bttv3, bttv7
218: 64296 0 PCI-MSI-edge eth0
NMI: 0 0 Non-maskable interrupts
LOC: 1108490 1305012 Local timer interrupts
RES: 5005 190785 Rescheduling interrupts
CAL: 47 144 function call interrupts
TLB: 233 399 TLB shootdowns
TRM: 0 0 Thermal event interrupts
SPU: 0 0 Spurious interrupts
ERR: 0
MIS: 0
monitor:~# ipcs -l
------ Shared Memory Limits --------
max number of segments = 4096
max seg size (kbytes) = 262144
max total shared memory (kbytes) = 1073741824
min seg size (bytes) = 1
------ Semaphore Limits --------
max number of arrays = 128
max semaphores per array = 250
max semaphores system wide = 32000
max ops per semop call = 32
semaphore max value = 32767
------ Messages: Limits --------
max queues system wide = 1758
max size of message (bytes) = 8192
default max size of queue (bytes) = 16384
/etc/sysctl.conf
kernel.shmall=268435456
kernel.shmmax=268435456
Thanks for answers
