I have searched over the forums for the past couple of days trying to find a solution to my problem. I have found a couple places where people are having a similar issue but their fixes are not working for me, so at the risk of being flamed for asking whats already been answered,.........
I purchased a PV-981 16ch card from Bluecherry.net.
http://store.bluecherry.net/Provideo_PV ... 981-16.htm
I'm using the Bluecherry live CD based on Xubuntu. Everything loads properly and I am able to see 8 of the cameras. Specifically I can see Video0/0-Video3/0 and Video0/1-Video3/1. It's my understanding that the other 8 cams should be at Video0/2-video3/2 and video0/3-video3/3 however when I add these it just gets a broken image icon and it also breaks the corresponding channels that are working. In other words, If I have the first 8 added to zoneminder and then add Video0/2 it not only doesnt work but it also breaks video0/0 and video0/1.
I would really appreciate any help anyone could offer. According to bluecherry this is just supposed to work without any modprobe commands but when I told bluecherry support it was on zoneminder they will only point me to the zoneminder forums.
Only getting 8 of 16 channels
May have it solved
I stumbled across another post that may be the answer.
http://www.zoneminder.com/forums/viewto ... t=channels
perhaps the cards need some modprobing after all.
