problem with zms streaming at different scales
rrrozman
Post by rrrozman »
I'm new in ZM and have problems with ZM watch window. If I set scale to 2x (from 320x240 to 640x480), then stills are twice the size, but if I switch to Stream, then html embedded windows media player displays only twice width and single height. I've checked html source and it seems to be set correctly at 640x480 - so I suspect that maybe zms is streaming at wrong size (640x240) ?
Is this my setup problem or zms ?
Thanks in advance,
regards,
Rob.
cordel
Post by cordel »
Mine works, using asf streaming I can select x2 and have the proper 640x480 window. Same with jave client works fine. I'd look into your settings. You might check on another machine and see if you can duplicate the issue on another Mediaplayer before you change anything though.
rrrozman
Post by rrrozman »
cordel wrote:Mine works, using asf streaming I can select x2 and have the proper 640x480 window. Same with jave client works fine. I'd look into your settings. You might check on another machine and see if you can duplicate the issue on another Mediaplayer before you change anything though.
I'm getting same behaviour from two machines with different versions of WMP. I guess I messed up settings, but have no idea where to look.
Where could I find more info about asf streaming. I even don't know what kind of streaming I'm using (stream is mpeg type).
Is there any more info about setting up Java client (it doesn't seem to work for me...).
Any hint ?
Thanks in advance,
Robert.
